Check Engine Light Reset - Page 2 - JeepForum.com
post #16 of 30 Old 03-28-2012, 12:37 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by jeepinjeffrey View Post
Yes you can have the coed show up in the little odometer screen and use that chart to decode the codes.
For a 1998 - Present TJ
in 1998, Chrysler upgraded the Jeep's internals to include their revised system used across many Chrysler fuel-injection models. This newer system still provides for reading the codes yourself. But how you do it and actual codes themselves are different from the 1997 and earlier models.
The method you use to view the engine diagnostics is now different. Starting in 1998, the method of repeatedly switching on/off of the ignition is now used for programming the new Chrysler Sentry Key system. The Sentry Key was introduced in 1998 as an optional feature and by 2000 was standard on all TJs. Some 1998 models without the Sentry Key system may still use the older procedure. The way to tell if your Jeep has the Sentry Key system is if the plastic head on your keys are gray--you do. Black headed keys mean you don't have the Sentry Key system.
So on TJs with the newer diagnostic system, to see the codes you put the key into the ignition, push and hold down the odometer reset button, turn the key to RUN, then release the odometer reset button. When you do this you are rewarded with dancing number displays, the firmware version number, any error codes, then a diagnostic test of all the dash indicators and gauges. The gauges will, one by one, go through a calibration--the needles moving and stopping at major increments so you can check their alignment with the dial markings.
Output from the newer onboard diagnostics is easier to read now, as you get full 4-digits codes for much greater detail.
I can not read any codes on my odometer in my 2000 Sport. I have to use a code reader.
My 2000 also doesn't have the Sentry system.
If you hold down the odometer reset button and turn the key on, all it does is an instrument cluster test, no OBD II display.
Where do you come up with this stuff?...
Knuckelhead is offline
post #17 of 30 Old 03-28-2012, 12:39 AM
Knuckelhead
AFSOC Retired
or try this
put key in ignition
turn key "on"
turn key "off"
turn key "on"
turn key "off"
turn key "on"
turn key "off"
Code displays on odometer
If you follow that sequence, nothing will be displayed on any TJ odometer...
post #18 of 30 Old 03-28-2012, 09:25 AM
GM92
or try this
put key in ignition
turn key "on"
turn key "off"
turn key "on"
turn key "off"
turn key "on"
turn key "off"
Well he was close, 3rd time leave key on until code(s) or "done" is displayed in odometer. May not work on '00 - '02 models due to PCM differences.
From the FSM: After three good trips the MIL is extinguished and the Task Manager automatically switches the trip counter to a warm-up cycle ounter. DTCs are automatically erased following 40 warm-up cycles if the component does not fail again.
'05 TJ RED RME
GM92 is offline
post #19 of 30 Old 03-28-2012, 09:32 AM
SlackJaw
baby jeep
SlackJaw's Avatar
wow. okay this saves me a trip to Autozone to have them read. as always, thanks fellers
SlackJaw is offline
post #20 of 30 Old 03-28-2012, 09:32 AM
purplepig
Only hard codes will come back on after you pull the battery ...soft codes will be wiped clean
What is the diff? I had a MAP sensor code come up. It was cleared and never came back. I have been wondering if it is still there.
same here.... atleast not with the on/off method
purplepig is offline
post #21 of 30 Old 03-28-2012, 09:44 AM
angelo2975
It will work for the 2002, one thing i didn't see mentioned is don't turn the key to crank ...just to the "accessory on" position
angelo2975 is offline
post #22 of 30 Old 03-28-2012, 11:54 PM
jeepinjeffrey
I googled it and got if from a website sorry.
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #23 of 30 Old 03-29-2012, 12:23 AM
Knuckelhead
AFSOC Retired
Well, it would help if you'd stop posting things as fact when you don't know if they are...
post #24 of 30 Old 09-15-2012, 05:58 PM
aash918
It's not your gas cap. It's a $12.00 gasket that's located between the muffler and the polution devise. Call your dealer, they'll know what it's called and tell you it's location. Very easy fix. Had the same problem.
aash918 is offline
post #25 of 30 Old 06-06-2013, 08:04 PM
ScruffMcGruff
Bringing this thread back from the dead.
My check engine light came on yesterday. A few days ago the engine would bog down and then come back to life while I heard a loud clanking sound under the Jeep. This happened a few times then stopped. Then yesterday the Check Engine light came on and has stayed on, but it has not bogged down since.
I tried it.. nothing happened.
or try this
put key in ignition
turn key "on"
turn key "off"
turn key "on"
turn key "off"
turn key "on"
turn key "off"
This worked.. sort of. It went through all the gauge readings, but did not show an error code. All it showed was my odometer reading.
I don't want to go to the auto parts store and have them check it, because I don't want them selling me useless items to "fix" it, such as blinker fluid.
Any more suggestions?
What makes hearing children’s laughter scary?
They’re giggling because they set something on fire.
ScruffMcGruff is offline
post #26 of 30 Old 06-06-2013, 11:05 PM
Knuckelhead
AFSOC Retired
You need a code reader for your 1998...
post #27 of 30 Old 06-07-2013, 07:33 AM
TJJeepJosh
works on my tj odometer..Maybe I don't have a TJ
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #28 of 30 Old 06-07-2013, 07:52 AM
purplepig
Do you have any recommendations for a code reader? I have been wanting to buy a good one.
post #29 of 30 Old 06-07-2013, 04:20 PM
Knuckelhead
AFSOC Retired
If your key is in the off position, nothing will be displayed in the odometer display...
post #30 of 30 Old 06-07-2013, 04:21 PM
Knuckelhead
AFSOC Retired
I bought a cheap one from HF, maybe someone else can make a recommendation?...
check , engine , light , reset
how to reset check engine light dawgknight TJ Wrangler Technical Forum 22 04-11-2016 11:09 AM
Check engine light reset. Char250r TJ Wrangler Technical Forum 3 06-17-2010 07:54 AM
Check engine Light 03' 2.4 reset Gunkel TJ Wrangler Technical Forum 11 05-07-2006 08:45 AM
How to Reset the computer (Check engine light)? BNovak TJ Wrangler Technical Forum 3 06-27-2004 04:54 PM
Check Engine Light reset skatedork TJ Wrangler Technical Forum 16 06-19-2003 10:59 AM
