Check Engine Light Reset - JeepForum.com
post #1 of 30 Old 07-17-2010, 08:38 PM Thread Starter
ShaneC
I have a 2000 Wranger and my check engine light was came on and Autozone told me I needed to replace my fuel cap. I did but the lights still on. Is there a way to reset the light or is there most likely still a problem?
ShaneC is offline
post #2 of 30 Old 07-17-2010, 08:49 PM
RubiconBlack
AutoZone likes to sell parts! Even if your vehicle doesn't need they tell you. Check out the "2004 jeep liberty running rough help" and see what AutoZone told him. http://www.jeepforum.com/forum/f19/2...-help-1066711/
I'm not saying they where wrong! If the problem is fixed the light will go out on its own after two or three trips. Basically when you drive it long enough for all the computers to say that everything is in working order two or three times.
RubiconBlack is offline
post #3 of 30 Old 07-17-2010, 08:53 PM
noise_maker
unfortunately on the 2000 due to a wire harness change you may have to have it cleared via odbII reader.
on the 99s and 01s you read and clear the codes using the key but on the 2000s it doesn't always work Before I bought a reader I use to get autozone to clear them for free for me.
I bought one of these a year ago for $12 - you have to watch the auctions though to find it that cheep. even at $30 its still way cheeper then the hand tools and works great
http://cgi.ebay.com/ebaymotors/BLUET...Q5fAccessories
noise_maker is offline
post #4 of 30 Old 07-17-2010, 09:02 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Disconnect the battery for 30 seconds and then reconnect it...
Knuckelhead is offline
post #5 of 30 Old 07-17-2010, 09:56 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
And if that doesn't work.... you didn't need a fuel cap!
GOLENJEEPTJ is offline
post #6 of 30 Old 03-27-2012, 09:00 PM
Echos58
Does anyone key sequence to turn off engine light on 2001 wrangler
Echos58 is offline
post #7 of 30 Old 03-27-2012, 09:05 PM
SlackJaw
baby jeep
SlackJaw's Avatar
for real? will it work on '04?
SlackJaw is offline
post #8 of 30 Old 03-27-2012, 09:09 PM
joeyk803c
drive it for a few days, if the problem is fixed the code goes away.
joeyk803c is offline
post #9 of 30 Old 03-27-2012, 09:10 PM
angelo2975
Only hard codes will come back on after you pull the battery ...soft codes will be wiped clean
angelo2975 is offline
post #10 of 30 Old 03-27-2012, 09:59 PM
DET_99TJ
how do you read and clear codes by key?
DET_99TJ is offline
post #11 of 30 Old 03-27-2012, 10:06 PM
jeepinjeffrey
I dont think you can clear codes with the key but you can read them http://www.quadratec.com/jeep_knowle...article-39.htm
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #12 of 30 Old 03-27-2012, 10:41 PM
Knuckelhead
AFSOC Retired
Yes.
You have to use a code reader for 1998-2000. You can't clear the codes using the key to read the codes on the odometer...
post #13 of 30 Old 03-27-2012, 10:49 PM
SlackJaw
baby jeep
SlackJaw's Avatar
If I may, and I may be not understanding as well.
Are you saying there is a way to use the ignition key to diplay the code on the odometer???
I think your link just showed code definitions.
I would also like to know how to do this, if I'm not entirely misreading your posts.
SlackJaw is offline
post #14 of 30 Old 03-27-2012, 11:20 PM
jeepinjeffrey
Yes you can have the coed show up in the little odometer screen and use that chart to decode the codes.
For a 1998 - Present TJ
in 1998, Chrysler upgraded the Jeep's internals to include their revised system used across many Chrysler fuel-injection models. This newer system still provides for reading the codes yourself. But how you do it and actual codes themselves are different from the 1997 and earlier models.
The method you use to view the engine diagnostics is now different. Starting in 1998, the method of repeatedly switching on/off of the ignition is now used for programming the new Chrysler Sentry Key system. The Sentry Key was introduced in 1998 as an optional feature and by 2000 was standard on all TJs. Some 1998 models without the Sentry Key system may still use the older procedure. The way to tell if your Jeep has the Sentry Key system is if the plastic head on your keys are gray--you do. Black headed keys mean you don't have the Sentry Key system.
So on TJs with the newer diagnostic system, to see the codes you put the key into the ignition, push and hold down the odometer reset button, turn the key to RUN, then release the odometer reset button. When you do this you are rewarded with dancing number displays, the firmware version number, any error codes, then a diagnostic test of all the dash indicators and gauges. The gauges will, one by one, go through a calibration--the needles moving and stopping at major increments so you can check their alignment with the dial markings.
Output from the newer onboard diagnostics is easier to read now, as you get full 4-digits codes for much greater detail.
2003 Wrangler Sport
post #15 of 30 Old 03-27-2012, 11:21 PM
jeepinjeffrey
or try this
put key in ignition
turn key "on"
turn key "off"
turn key "on"
turn key "off"
turn key "on"
turn key "off"
Code displays on odometer
2003 Wrangler Sport
check , engine , light , reset
how to reset check engine light dawgknight TJ Wrangler Technical Forum 22 04-11-2016 11:09 AM
Check engine light reset. Char250r TJ Wrangler Technical Forum 3 06-17-2010 07:54 AM
Check engine Light 03' 2.4 reset Gunkel TJ Wrangler Technical Forum 11 05-07-2006 08:45 AM
How to Reset the computer (Check engine light)? BNovak TJ Wrangler Technical Forum 3 06-27-2004 04:54 PM
Check Engine Light reset skatedork TJ Wrangler Technical Forum 16 06-19-2003 10:59 AM
