Check engine light reset. - JeepForum.com
post #1 of 4 Old 06-17-2010, 07:18 AM Thread Starter
Char250r
Light came on. Had it scanned. O2 sensor was NG. Changed it. Runs like new again. Need to reset check engine light. Can I reset it with out the scanner?
Char250r is offline
post #2 of 4 Old 06-17-2010, 07:48 AM
Sundowner
http://www.jeepforum.com/forum/f9/ho...-light-974645/
Sundowner is offline
post #3 of 4 Old 06-17-2010, 07:52 AM
Zen
You can unplug the 4 wiring harnesses that hook up to the computer on the passenger firewall. Leave them unhooked for 30 sec then plug 'em back in. Be carefull to push straight in when hooking them back up. You will wipe the PCM clean and the Jeep will need to "relearn" idle and LT/ST fuel trims, but you will not erase the radio settings. Start the Jeep and allow it to idle a few minutes in park, then in gear, then drive it for about 10-15 miles after it has completely warmed up. You should do this anytime you replace o2 sensors.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #4 of 4 Old 06-17-2010, 07:54 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Disconnect the negative battery cable.
TheBoogieman is offline
how to reset check engine light dawgknight TJ Wrangler Technical Forum 22 04-11-2016 11:09 AM
Check Engine Light Reset Procedure WORKS! YEA! Overdrive TJ Wrangler Technical Forum 11 12-16-2006 11:28 PM
Check engine Light 03' 2.4 reset Gunkel TJ Wrangler Technical Forum 11 05-07-2006 08:45 AM
How to Reset the computer (Check engine light)? BNovak TJ Wrangler Technical Forum 3 06-27-2004 04:54 PM
Check Engine Light reset skatedork TJ Wrangler Technical Forum 16 06-19-2003 10:59 AM
