check engine light question? - JeepForum.com
post #1 of 4 Old 10-12-2006, 08:12 AM Thread Starter
REDPILL
REDPILL's Avatar
My check engine light came on, while driving today. I checked the code through the key on/off sequence and it came up with a P0442 code. All I have found is its some kind of vaccume code. Can anyone tell me about this code? And the fix!!
Thanks in advace,
jclaude
PS. I did check all my vac. hoses and they appear to be good(no dry cracks or holes).
Originally Posted by JeepGirl04 View Post
when it doubt... pull it out
Matthew 6, 5-6 Read it, Follow it.
2004 unlimited Yellow
REDPILL is offline
post #2 of 4 Old 10-12-2006, 08:21 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That's an evaporative leak, not a vacuum leak. That could be gas cap related, ceck your gas cap to see if it's tight. Did you happen to refill with your engine running or not tighten the gas cap down all the way?
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #3 of 4 Old 10-12-2006, 09:31 AM
ColoradoTJ
ColoradoTJ's Avatar
x2 on the gas cap, I've got the same code before, just had to tighten my gas cap (three clicks) and get the code reset.
Clint
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline
post #4 of 4 Old 10-12-2006, 11:32 AM Thread Starter
REDPILL
REDPILL's Avatar
Just filled up with gas a day ago. I'll check to make sure its tight.
Thanks,
jclaude
REDPILL is offline
check engine light question 92renegade YJ Wrangler Technical Forum 17 01-15-2010 07:38 PM
check engine light question greta TJ Wrangler Technical Forum 3 06-15-2009 11:18 AM
Check engine light question agent_J TJ Wrangler Technical Forum 2 08-17-2008 05:43 PM
Question - Check engine light odie6423 TJ Wrangler Technical Forum 3 04-16-2007 05:10 PM
Check engine light question Jim Smyth TJ Wrangler Technical Forum 4 05-20-2005 05:18 AM
