Check engine light-power steering pressure switch - JeepForum.com
post #1 of 4 Old 03-04-2009, 01:48 PM Thread Starter
rudyyj
i'm having a problem with my check engine light/error codes
97 TJ w/4 cylinder
the light is on.
codes:
12--battery disconnected
65--Power steering high pressure seen at high speed. (2.5L only)
55--Completion of fault code display on Check Engine lamp.
65 is not supposed to trigger the MIL
i have replaced the power steering switch--still returns
i have disconnected the switch--still returns
I have jumped the switch--still returns
the way i read the circuit is the switch goes to ground--the PCM sees ground when the switch closes due to high pressure and then ups the RPM for parking lot maneuvers
so, the only thing i haven't checked (tonight) is if the wire going to the switch is damaged and grounding out.
my questions...
1) why is it turning on the MIL--65 is not supposed to turn the light on
2) is there a way to "reprogram" so it doesn't look for the input from the power steering pressure switch?
3) Does the PCM query the switch?... will it give an error if there is no change in the reading for an extended period of time
i need this blasted light off for inspection
scott
rudyyj is offline
post #2 of 4 Old 03-04-2009, 03:45 PM
kloppk
scott
Just the opposite. The switch is normally closed and only opens if it sees high pressure (a heavy power steering demand)
Try connecting the Dark Blue/Brown wire that connects to the switch to Ground and reset the PCM. This should keep the Check Engine light off.
From the FSM...
POWER STEERING PRESSURE SWITCH—PCM
INPUT
A pressure sensing switch is included in the power
steering system (mounted on the high-pressure line).
This switch will be used only on vehicles equipped
with a 2.5L engine and power steering. The switch
(Fig. 9) provides an input to the Powertrain Control
Module (PCM). This input is provided during periods
of high pump load and low engine rpm; such as during
parking maneuvers. The PCM will then increase
the idle speed through the Idle Air Control (IAC)
motor. This is done to prevent the engine from stalling
under the increased load.
When steering pump pressure exceeds 3275 kPa 6
690 kPa (475 psi 6 100 psi), the normally closed
switch will open
and the PCM will increase the
engine idle speed. This will prevent the engine from
stalling.
kloppk is offline
post #3 of 4 Old 03-04-2009, 03:46 PM Thread Starter
rudyyj
thank you i will try that tonight!!!!
thats the only thing i didn't try...i left it open and in jumped the two wires but didn't ground them...thanks for bringing a fresh idea to my issue
scott
rudyyj is offline
post #4 of 4 Old 03-09-2009, 09:17 AM Thread Starter
rudyyj
thank you.... problems fixed
turned out to be a broken wire between the switch and the PCM...
my FSM was wrong...it is a normally closed switch that opens with pressure as was stated above by kloppk.
I decided i didn't need the RPM to increase, it might be more necessary with an automatic. So i just took a wire from the pressure switch wire before the break(near the PCM) and took it to ground. The Pressure switch is normally closed (showing ground to the PCM) until high pressure is seen, now my PCM always sees ground.
scott
rudyyj is offline
Power steering fluid leaking. Pressure switch? ROLNOVR TJ Wrangler Technical Forum 3 04-13-2009 01:03 PM
check engine light/power steering 97okwrangler TJ Wrangler Technical Forum 3 12-14-2008 05:38 PM
Power steering high pressure switch ? KenF YJ Wrangler Technical Forum 7 12-18-2007 09:56 PM
Power Steering High Pressure Switch 1stTimeJeeper TJ Wrangler Technical Forum 3 08-13-2007 01:37 PM
Power Steering Pressure Switch Tiffy TJ Wrangler Technical Forum 1 09-23-2003 09:58 AM
