check engine light with no codes - JeepForum.com
post #1 of 9 Old 08-05-2012, 04:26 PM Thread Starter
98TJKonaCruiser
hello, looking for some help/advice. i have a 97.5(98) TJ and I tried the key check maneuver to find the error code for my CEL being on and no code appears. i only see the mileage on jeep, and no lights flash on and off.
am i doing something wrong? i turned the key position on>off>on>off>on, and then waited up to 5 mins. i don't know if i need to wait longer or do anything else. please help.
also, what is good to remove corrosion build up on battery terminals?
98TJKonaCruiser is offline
post #2 of 9 Old 08-05-2012, 04:49 PM
asim04LJ
Did you do the key maneuver in less than 10 seconds?
asim04LJ is offline
post #3 of 9 Old 08-05-2012, 04:51 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
1998-2000 TJ's don't have that function.
Take it to a automotive parts store and have the code read for free, or buy your own code reader.
A wire brush works well for cleaning the battery terminal clamps/posts...
Knuckelhead is offline
post #4 of 9 Old 08-05-2012, 05:42 PM Thread Starter
98TJKonaCruiser
i did what was listed on this page.
http://myjeeptj.com/2008/04/20/1998-...agnostic-codes
post #5 of 9 Old 08-05-2012, 07:25 PM
mukluk
As already pointed out by Knuckelhead, the on/off key trick does not work on 1998-2000 Wranglers. You are going to have to use a code reader to find out why you have a check engine light.
mukluk is offline
post #6 of 9 Old 08-05-2012, 09:39 PM
GilaMtnJeep
GilaMtnJeep's Avatar
What he said^^^^
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #7 of 9 Old 08-06-2012, 02:32 AM Thread Starter
98TJKonaCruiser
will do. thanks to all.
post #8 of 9 Old 08-06-2012, 04:59 AM
boondaba
At first I thought you were being immature by calling him a "Knuckelhead"
My 5.3 Build
boondaba is offline
post #9 of 9 Old 08-10-2012, 07:21 AM
CJ Chet
On that battery, use baking soda (good old Arm and Hammer) and water. Works like a champ!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
98 tj , battery terminals , check engine light
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 05:05 PM
Need help with check engine light codes ReyesYJ YJ Wrangler Technical Forum 0 03-02-2009 07:51 PM
Check engine light codes? roundedge4lfe YJ Wrangler Technical Forum 3 06-07-2007 03:25 PM
Check engine light and codes Muddman TJ Wrangler Technical Forum 5 10-13-2005 07:03 PM
check engine light codes asjeep TJ Wrangler Technical Forum 2 09-12-2003 07:04 AM
