check engine light with message "No Bus"?? - JeepForum.com
post #1 of 6 Old 03-16-2005, 12:49 PM Thread Starter
SteelBlueTJ
Started up my Jeep this morning and shortly after I started it the check engine light comes on along with the airbag light. Then the odomoter display reads "No Bus". I shut the jeep off and started it back up and its fine. The light never came back on. What is going on? Anyone know what this is? I tried to check for error codes but none came up. It also did this a couple weeks ago on my way to work as well. It doesn't seem to affect anything, the jeep still runs and drives great. I just thought someone on here might know something about this. Thanks for any help.
SteelBlueTJ is offline
post #2 of 6 Old 03-16-2005, 01:00 PM
Jim Shanks
Jim Shanks's Avatar
That means there is not an H2 anywhere in site so you don't have to worry about them trying to follow you offroad and then worry about having to pull them out.
I'm sorry couldn't resist.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #3 of 6 Old 03-16-2005, 01:43 PM
Varnish
Varnish's Avatar
i'm sure its on this forum too but...
http://4wd.com/4wdforums/showthread....&highlight=bus
'98 TJ, '06 LJ, '88 YJ, '86 CJ, '99 XJ 4dr Ltd
Varnish is offline
post #4 of 6 Old 03-16-2005, 01:51 PM
kaybone
You can't check error codes on a 99. It is one of the few years of Jeeps that doesn't have the on board reader. Go out and get yourself on of those cheap Harbour freight readers for about $38. That's what I did and it works great
Gun Metal Blue Jeep Club Member #99
kaybone is offline
post #5 of 6 Old 03-16-2005, 02:07 PM Thread Starter
SteelBlueTJ
Thanks for you help!
post #6 of 6 Old 03-16-2005, 02:18 PM
kaybone
No Problem. Gun metal Rules!
kaybone is offline
"Check Engine Light" and engine code P0442 MDC3 TJ Wrangler Technical Forum 3 08-05-2009 02:38 PM
Unichip, Supercharger and "check engine light".... Busa196 JK Wrangler Technical Forum 18 02-13-2008 09:43 AM
HELP! Jeep has been "coughing" and check engine light came on... what might it be? hangwire TJ Wrangler Technical Forum 12 09-06-2007 02:15 PM
How do I turn "check engine" light off? Code.. Q-01 TJ Wrangler Technical Forum 7 01-28-2006 02:28 PM
"Check Engine" light is on, but no error codes gdixon TJ Wrangler Technical Forum 13 02-29-2004 01:25 PM
