Check Engine Light Help - JeepForum.com
post #1 of 3 Old 06-28-2010, 10:49 AM Thread Starter
CalaskanTJ
I am on vacation in Colorado and took the Jeep out riding trails twice so far and the check engine light keeps coming on. It happened both times when I was decending some steep trails in 4lo. I could smell something almost like fluid getting really warm and then the check engine light would come on. I drove into autozone to get it diagnosed yesterday, but the code it was giving was for the mass air flow sensor, which the print out said it could be from a cracked vacuum line or something. I am thinking that the smell was coming from either the transmission or the transfer case because it was really the only thing working hard at the time.
Has anyone else ran into this issue before? I don't want to get stranded on some trails out here in CO!
1997 TJ. 4.0, 5spd. 4" Lift, 33" MTR's, D30 front with ARB, rear 8.8 with ARB, 4.10 gears, KC Slimlites, Superwinch EPi9.0s, Hi-lift Jack. Trail Gear front bumper, rear bumper/tire carrier, rock sliders and steering skid.
UTAH JEEPCREW #20
CalaskanTJ is offline
post #2 of 3 Old 06-28-2010, 10:51 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I would double check that code.
TJs do not use a MAF sensor.
You do not need a scanner to pull the code. Here's how:
http://www.jeepforum.com/forum/f9/fa...-codes-778086/
Wheelin98TJ is offline
post #3 of 3 Old 06-28-2010, 10:52 AM
Sundowner
Mass airflow sensor??? What code were you getting? Did you visually check your vacuum lines?
Sundowner is offline
check engine light , CEL
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 02:19 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 09:02 AM
O/D Light Not Working & Check Engine Light On JeepMom2 TJ Wrangler Technical Forum 2 12-24-2006 09:43 AM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 05:48 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-27-2003 12:43 AM
