Check Engine Light Error Code P0432 PICS! - JeepForum.com
post #1 of 9 Old 01-07-2007, 09:02 PM Thread Starter
cyclerider105
cyclerider105's Avatar
Hey all,
Looked at the FAQ section and did a search for this code. The question I have is that it appears that my 04 with an I6 has 4, count them FOUR O2 sensors. Most of the posts I found seem to indicate that this code (P0432) indicates a bad O2 sensor. Question is the code indicates a problem in BANK 2. So, which sensors are bank 2? I am attaching some pics. My O2 sensors are all together. 2 are located right below the manifold in the first pic and 2 are located about a foot lower in the exhaust system in the second pic. None of the sensors are back by the CAT. Weird! Anyone else had this problem code with this O2 set up and how did you resolve it? ANY help is appreciated!
The upper two sensors:
The lower two sensors:
cyclerider105 is offline
post #2 of 9 Old 01-08-2007, 02:07 AM Thread Starter
cyclerider105
Just a little bump
post #3 of 9 Old 01-08-2007, 04:16 AM
snccoulter
snccoulter's Avatar
P0432 Catalyst System Low Efficiency Bank 2 this is your issue the F%$k if i know what it means here is a link for the error codes
http://www.coulters-inc.com/page3.html
Get your family involved!!
/ | ,[____],
|--L-0||||||0-
()_) ()_)----)_)
98 Sahara - Soft Top 6" Lift - Sway Bar Quick Disconnects - Pro Comp33-12.5-R15
The problem with doing nothing is not knowing when you are finished. Benjamin Franklin
Check out
snccoulter is offline
post #4 of 9 Old 01-08-2007, 06:40 AM
hbomb695
hbomb695's Avatar
The newer jeeps have a 2 stage catalytic converter system. the first stage is located between the sets of O2 sensors. The upstream sensor regulates the fuel/air ratio, while the sole purpose of the downstream sensor is to monitor the efficiency of the stage 1 cat (2 of them, hence 2 upstream and 2 downstream sensors). Bank 2 is the rear-most of the two.
Check the lower sensor (downstream) on that bank. If the sensor is ok, then you have a stage 1 catalytic converter failure. Fortunately, that assembly is covered under a federally mandated 8 year, 80,000 mile emissions warranty ($359 for the part if you're outside that).
I don't work to live. I work to support my offroad habit.
hbomb695 is offline
post #5 of 9 Old 01-08-2007, 08:33 AM
Fox Fader
If you need an o2 sensor go to oxygensensors.com, best prices. For an 04 Jeep you have to call them for more info.
God Rules!
Fox Fader is offline
post #6 of 9 Old 01-08-2007, 11:37 PM Thread Starter
cyclerider105
Thanks for the info! You explained it very well! Of course, I have 81K on the rig!!!!!!!! So, looks like it is on me!
post #7 of 9 Old 07-17-2012, 10:41 AM
gizelgazelle
Same problem on my 2003.
Hey cyclerider105-
Did you have any luck replacing the o2 sensor? I'm getting the same code. I can't believe that the main cat is bad. My Jeep runs fine.Which sensors are for bank 2? I've got to take my Jeep in for an emissions test. Could you let me know how you fixed your problem? Thanks!
gizelgazelle
gizelgazelle is offline
post #8 of 9 Old 07-17-2012, 11:02 AM
gebirgziege
Interesting. Mine just threw the code again too. But mine is an 06 and I have 25k on her.
Are 02 sensors covered by that federal emissions warranty?
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #9 of 9 Old 07-17-2012, 11:17 AM
2003RubiBlue
I had this same thing happen twice. The first time I was under emissions warranty and ended up just paying for the 02 sensors. The second time I was way out of warranty and I did the 2 mini cats, main cat, 4 os sensors, hangers, associated hardware, and a cat back for about $1000 using all Rockauto parts. If you need the cats as someone said above the 2 min cats are like $400. Oh and please if you do decide to replace just the 92 sensors to diagnose the problem do not use Bosch. The Bosch do not play well with the Ecu, use NGK they are the OEM manufacturer and they are actually cheaper than Bosch.
Good Luck any Q's just ask.
Brian
Will work for Jeep parts...
2003RubiBlue is offline
Check Engine light - What else would cause the error code 23 other than bad sensor dbaum77 TJ Wrangler Technical Forum 3 08-31-2008 05:40 PM
Check Engine Light: Code p0432 MB98XJ TJ Wrangler Technical Forum 13 08-13-2008 10:38 PM
Check Engine Light and Error Code... rmb2485 TJ Wrangler Technical Forum 1 04-15-2007 06:44 PM
check engine light, error code 25 again cutlass1972 TJ Wrangler Technical Forum 2 03-28-2006 12:37 PM
Error Code 121 Check engine light from PARAGON HELP!? tomkirkland4 TJ Wrangler Technical Forum 5 04-04-2005 09:31 AM
