Quantcast Check Engine Light Codes P0300 & P0301 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Check Engine Light Codes P0300 & P0301
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 12-31-2007, 09:39 AM   #1
Ichabod1960
Have Jeep, Will Travel
Ichabod1960's Avatar
I'm in the St. Louis area visiting family and friends and until last night my LJ was running fine. When I went to start up the Jeep last night the check engine light went on and it ran a little rough for a minute or so.
I just got back inside from getting the code and the codes are P 0300 and P 0301. How serious are these codes and what should I do to reset the check engine light?
Thanks,
Drew
Originally Posted by Jerry Bransford
There's a great lower division class called "Writing for Effective Communications so you don't go through the rest of your life confusing everyone who reads what you write 101" at Washington State University. I highly recommend it.
Ichabod1960 is offline   Reply With Quote
Old 12-31-2007, 09:45 AM   #2
Nonya
That code means the cylinders have random misfires,could be so many different causes.From 02 sensors to sopark plugs or even bad gas.Is is running bad?If you have to drive a long distance i would let a dealer take a quick look at it.Don't bother resetting the check engine light,it will just come back on.
Nonya is offline   Reply With Quote
Old 12-31-2007, 10:02 AM   #3
robncar
The P0300, as stated above, is a "Multiple Cylinder Misfire"
The P0301 is a "Cylinder No. 1 Misfire"
I suppose you could perform a visual inspection, pull plug number one and take a look, or just let a dealer take a quick peek.
Listed as possible causes:
INTERMITTENT MISFIRE
VISUAL INSPECTION
(F142), (K334) ASD RELAY OUPUT CIRCUIT
ENGINE MECHANICAL PROBLEM
IGNITION COIL
COIL CONTROL CIRCUIT
SPARK PLUG
CHECKING FUEL PRESSURE
FUEL PUMP INLET STRAINER PLUGGED
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP MODULE
CHECKING FUEL LEAK DOWN
FUEL INJECTOR
INJECTOR CONTROL CIRCUIT
PCM
DON'T FEAR THE RE-GEAR!!!
______
|_____|
(O|||||||O)
|______|
[]===o==[]
RED JEEP CLUB MEMBER #430
robncar is offline   Reply With Quote
Old 12-31-2007, 10:03 AM   #4
Ichabod1960
Once the engine warms up, it runs fine. I'll get a hiccup or two right as I start out, usually shifting from 1st into 2nd and then the Jeep runs fine.
I just need to run around St. Louis today about 50 miles but tomorrow I need to drive about 100 miles to my parents house. I can get the Jeep to the dealer on Wednesday before I drive the 800 miles to SC on Thursday or Friday.
Drew
Old 12-31-2007, 11:53 AM   #5
buellwinkle
Consider it a warning that can turn ugly on a moments notice. Random misfires could mean you have a weak fuel pump, fpr, filer getting clogged, clogged injectors, possibly a vacuum leak, bad coilpack. It could be as simple as bad gas so you can reset the codes, refill with a good gas and see if it comes back.
2005 Solar Yellow X
Automatic/Soft Top/OME Shocks/RE 2" BB/31"x10.5" Tires
buellwinkle is offline   Reply With Quote
Old 01-01-2008, 12:56 AM   #6
Ichabod1960
Right now, I'm leaning toward the bad gas theory. The CEL has gone out and the engine has run fine all day today. I do have an appointment with a dealer on Wednesday and we'll see what he has to say.
Thanks for everyone's advice and help.
Drew
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
