Check engine light code trick? - JeepForum.com
post #1 of 8 Old 07-19-2010, 10:13 AM Thread Starter
Jaybob7
I went wheeling on Saturday and I caught a small tree stump on the way down. I backed up and went on my way. This morning my check engine light came on. I was reading in a forum that you can check the codes by holding the odometer button while turning the key and the code should display. Does anyone know if this works?
I have an 04 Rubi by the way.
Appreciate your feedback!
Jay
Last edited by Jaybob7; 07-19-2010 at 10:15 AM. Reason: Forgot to submit the Jeep model.
Jaybob7 is offline
post #2 of 8 Old 07-19-2010, 10:16 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
No, you use your key.Without starting the engine just turn the key on,off,on,off,on and leave it!Do this quickly,like within a few seconds.The codes will come up on your odometer!You don't press the odometer!
GOLENJEEPTJ is offline
post #3 of 8 Old 07-19-2010, 10:20 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Turn the ignition switch on-off-on (just to 'On' but not to start) three times within five seconds and then leave the key on. Several seconds later, any stored codes will show up in the odometer. Have patience, they don't show up immediately.
Jerry Bransford is online now
post #4 of 8 Old 07-19-2010, 01:29 PM Thread Starter
Jaybob7
Found code. The odometer states: "P0456". According to the forums it means the following: "Evaporative Emission Control System Leak Detected (very small leak)". The forums say that more than likely it’s the gas cap. I will make sure my gas cap is on tight and also check it to make sure it’s in good condition. After that's done I will disconnect the battery to reset the code. Hopefully the gas cap does the trick, but we'll see...
Jay
Jaybob7 is offline
post #5 of 8 Old 07-20-2010, 12:16 PM Thread Starter
Jaybob7
thightened the gas cap and clearer the code. Thanks guys! I just have to wait and see if it comes back.
Jay
Jaybob7 is offline
post #6 of 8 Old 09-27-2011, 08:56 AM
kenjoseph2000
guys thank you so much this trick worked flawlessly i have a p0455 code
kenjoseph2000 is offline
post #7 of 8 Old 03-13-2014, 04:58 PM
dan523
I had the same thing happened it was my gas cap and once I unplugged the battery it went away. I did have to reset the clock but for some reason I still have the radio stations preset saved it must have a backup battery or saved the stations in a short time!
dan523 is offline
post #8 of 8 Old 03-13-2014, 05:26 PM
LukeADukes
if there is a problem it will still be there. Unplugging it doesn't completely reset the PCM
Always look both ways before crossing the stream.
LukeADukes is offline
check engine , code , trick , diagnostic , tj , wrangler
Check engine light and code 2.5?? blacktjsport TJ Wrangler Technical Forum 5 07-11-2011 04:08 PM
Check Engine Light, what code? ScottJ83 TJ Wrangler Technical Forum 3 08-17-2009 12:11 AM
check engine light code RedWrapper TJ Wrangler Technical Forum 3 01-29-2007 02:15 PM
Check engine light -no codes w/ key trick? IAJack TJ Wrangler Technical Forum 3 04-19-2006 10:11 PM
Engine light and Error code trick habers TJ Wrangler Technical Forum 7 01-08-2005 09:33 AM
