Check engine light came on,then off. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Check engine light came on,then off.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 11-16-2009, 06:21 PM   #1
TJTB
Check engine light came on when cruising up to a light in neutral. Stayed on a couple of days. (Went off when I came out of the parts store to price code checkers.) Is rolling in neutral a no no?
TJTB is offline   Reply With Quote
Unread 11-16-2009, 06:28 PM   #2
callsigncowboy
Junior Member
callsigncowboy's Avatar
mine does that too and the code comes up as a bad o2 sensor it goes on and off all the time so id check that
2000 tj stick-shift 4 banger, stock for now but not for long
Bulit not Bought #65 nightcrew#284
www.chicagoheretics.com
callsigncowboy is offline   Reply With Quote
Unread 11-16-2009, 06:30 PM   #3
rivalarrival
Stormaggedon
rivalarrival's Avatar
You can check codes easily, without a scanner. With the engine off, turn the key on, off, on, off, on, off, on. (On = run, not start)
Your digital odometer display should display 2-digit codes, ending with "55". They should also blink out on the check engine light.
Alternatively, most part stores will read your codes for free.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine
We work together every damn day. --Jon Stewart
Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it.
Low Output 4 Cylinder Jeep Club member #188
rivalarrival is offline   Reply With Quote
Unread 11-16-2009, 08:52 PM   #4
BlueFlame
Odds are the code was TPS. They are famous for that. The TPS are rarely bad, it's the damn harness plug. Next time it does it, get your codes read at an auto parts store. If it's TPS, unplug it and plug it back in, be sure it's tight. The light will probably go out the next time you drive it.
BlueFlame is offline   Reply With Quote
Unread 11-17-2009, 06:06 PM   #5
TJTB
I tried that but couldn't get it to work.The local Parts source here does not check for free (or at any price)! Does NAPA do it in Canada?
Unread 11-17-2009, 08:44 PM   #6
00TJDave
Nah.... rolling in neutral is not a problem. I do it a lot....
I would just sit tight and see if it happens again. I think that things just get temporarily "stupid" on occasion.
00TJdave - we be jeepin'
Proud to be GREEN JEEP CLUB member #128 [O|||||O]
00TJDave is offline   Reply With Quote
