Check Engine light came on, same time my fuel started spilling over during fill up - JeepForum.com
post #1 of 2 Old 08-02-2010, 08:39 PM Thread Starter
Nielubie
Anyone have an Idea why my check engine light is on? It started happening the same time my Jeep started spilling fuel during fill ups. I had the codes read and its saying its a gas cap, so I bought a new gas cap and cleared the error and a day later the light came back on. Somehow related to the fuel spilling.
My fear is that the Jeep won't pass state emissions, so I need to get this fixed. :/
-=- 2006 Yellow TJ Rubicon -=-
-=- 4" Rough Country Lift, Front mounted Ramsey Winch, Rock Hard Rear Bumper -=-
-=- Currie Johnny Joint Arms, Currie Tie Rods, Cobra CB -=-
Nielubie is offline
post #2 of 2 Old 08-02-2010, 09:03 PM
dmgiff
Sounds like a problem with the vent. The little vent hose is what normally should keep it from overflowing as it allows air to escape from the top of the tank as fuel is rushing in. If you are overflowing, you might have an obstructed vent hose, though it seems unlikely. Your check engine light will come on if the smog gremlins think you may be unleashing raw fuel vapors to ravage the ozone and warm the globe. It's gotta be something back there. First things first... Disconnect the neg battery cable for a couple minutes to clear your computer codes... Reconnect and see if the check engine light comes back on. If it does, start investigating your fuel filler area since you already replaced your cap. Problem may be solved already. Your computer will continue to remind you there WAS a problem until you drive lots of miles or reset the codes. Hope this helps.
Just reread your post and saw you already cleared the codes. It's gotta be something back there. Same thing would probably cause overflow.
dmgiff is offline
check engine light , CEL
gas spilling out when i fill up my tank??wtf vicker YJ Wrangler Technical Forum 8 04-14-2010 07:35 PM
Check engine light came on for the first time, what do these mean? chaznad TJ Wrangler Technical Forum 0 03-28-2009 02:54 PM
97 4.0 runs great, bad fuel mileage,sut on tailpipe CHECK ENGINE light comes on jeepfreak_5 TJ Wrangler Technical Forum 2 12-21-2008 04:58 PM
Check Engine Light / Fuel Guage lukera TJ Wrangler Technical Forum 9 04-19-2006 08:01 PM
check engine light came on for the first time in my 98 sport today since I've had it illumin8em TJ Wrangler Technical Forum 14 01-16-2004 12:01 PM
