Quantcast check engine light came on, was an error 25 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > check engine light came on, was an error 25
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 03-05-2006, 02:43 PM   #1
cutlass1972
I got a junyard idle air control motor and replaced my existing onw with it. I am still getting the error 25, any advice?
cutlass1972 is offline   Reply With Quote
Old 03-05-2006, 03:56 PM   #2
JohnCub
25 A shorted or open condition detected in one or more of the idle air control motor circuits. Actual idle speed does not equal target idle speed.
JohnCub is offline   Reply With Quote
Old 03-05-2006, 04:21 PM   #3
cutlass1972
thanks for the info, but I already knew what the error code meant, that is why I replaced the idle air intake motor. I dont know why I still got an error 25 after repalcing the motor is the problem. I cleared the pcm and the check engine light went away, I will see in the next couple of days if it stays gone or if it comes back
Old 03-05-2006, 04:27 PM   #4
JohnCub
Oh, sorry, now that I reread your post I see you were actually pretty clear about that. I guess the old mind went into autopilot and took my fingers with it.
From a little searching I see that there is a missing OR in there.
25 should read:
A shorted or open condition detected in one or more of the idle air control motor circuits.OR Actual idle speed does not equal target idle speed.
I'd say check for a vaccum leak somewhere. I know that's vague but sometimes that will cause incorrect idle or rough idling.
Glock Forum
