check engine light came on. - JeepForum.com
post #1 of 7 Old 08-01-2010, 09:28 AM Thread Starter
NKYJEEPSTER1
My check engine light came on last night. I did the key 3 times and got the code p0129. From what I can find on the net, it is for Barometric Press Too Low. Any ideas on a fix for that?
Also my fuel gauge has started work incorrectly. When you fill it up, the gauge doesn t move. I was able to turn off the key and turn it back on, then the gauge would work. But that trick is slowly starting to not work. Is there anything tricky with these?
NKYJEEPSTER1 is offline
post #2 of 7 Old 08-01-2010, 09:38 AM
GilpinTJ
GilpinTJ's Avatar
A shot in the dark here......could the barometric pressure thing be a bad gas cap?
John P.
Colorado Jeep Club Member #494
GilpinTJ is offline
post #3 of 7 Old 08-01-2010, 09:56 AM Thread Starter
NKYJEEPSTER1
I haven t tried that yet, so any shot is a good shot at this point.
post #4 of 7 Old 08-01-2010, 10:38 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
TheBoogieman is offline
post #5 of 7 Old 08-01-2010, 10:41 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
It would help to know what year and what your Jeep is made up of? http://www.jeepforum.com/forum/f9/fi...ofiles-402432/
GOLENJEEPTJ is offline
post #6 of 7 Old 08-01-2010, 04:25 PM Thread Starter
NKYJEEPSTER1
2006 LJ Rubicon
Code was P0129
post #7 of 7 Old 08-01-2010, 04:36 PM
silver97tj
silver97tj's Avatar
MAP sensor! is the only one that measures air pressure on a jeep.
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
p9129 , cel , check , engine , light
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 01:19 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
O/D Light Not Working & Check Engine Light On JeepMom2 TJ Wrangler Technical Forum 2 12-24-2006 08:43 AM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 04:48 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
