Check engine light :( - JeepForum.com
post #1 of 8 Old 09-03-2010, 02:37 AM Thread Starter
SaskMud
Hey everybody, the check engine light came on after washing my engine compartment with some low pressure water. I don't know what I did. I made sure not to get any water on any electrical business and I put a rag in the air intake. It idols really low 750ish rpm, and almost stalls when I come to a stop (red light, stop sign etc). Also when it shifts up (its an automatic) it revs on and off around 2400 rpm and again around 2800rpm after it shifts into 3rd. Does anybody know what might be ailing my poor tj?
SaskMud is offline
post #2 of 8 Old 09-03-2010, 04:15 AM
Neil F.
You need to get the code to diagnosis. Key off-on-off-on-off-on and the code will display in the odometer. (I would guess the TPS which would be a 0122, 0123 but you need to get the code first)
Neil F. is offline
post #3 of 8 Old 09-03-2010, 07:49 AM
BYuen
BYuen's Avatar
And if that doesn't work for ya (some people can't get it to work) then just go to Autozone and they will read your code for free.
BYuen is offline
post #4 of 8 Old 09-03-2010, 07:58 AM
lostone73
2000 model wont do the key trick, only 2003 and later that utilized the j1850 serial bus data protocol. you have to scan that one. go to autozone
lostone73 is offline
post #5 of 8 Old 09-03-2010, 08:28 AM
IrishRED
4-Banger Forever!
IrishRED's Avatar
The "key trick" works just fine in my '97
Firefighters Jeep Club
__________
ll , [______] ,
l --- l_ -OllllllllO-
( )_) ( )_)--o-)_)
Low Output 4-Cylinder Jeep Club Member#91
IrishRED is offline
post #6 of 8 Old 09-03-2010, 08:37 AM
XtrmTJ
The "Key Trick" works just fine on my '97.
This same thing happened to me a long time ago. Most things under the hood do not like water/moisture. You must check all connections and make sure they are all dry. Apply a little of that electrical grease (?) to insure they stay dry. Oh yea, get the code first.
Semper Fi
GREEN JEEP CLUB Member #516
It's a ROCK, ... get over it !
XtrmTJ is offline
post #7 of 8 Old 09-03-2010, 09:25 AM Thread Starter
SaskMud
Thanks for the tips.
SaskMud is offline
post #8 of 8 Old 09-03-2010, 10:32 AM
BYuen
BYuen's Avatar
Key trick in my '01 works.
BYuen is offline
cel , check engine light , codes
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 01:19 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
O/D Light Not Working & Check Engine Light On JeepMom2 TJ Wrangler Technical Forum 2 12-24-2006 08:43 AM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 04:48 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
