Check engine Light 03' 2.4 reset - JeepForum.com
post #1 of 12 Old 05-01-2006, 11:46 AM Thread Starter
Gunkel
Gunkel's Avatar
The check engine light in my 03' TJ 2.4 will not shut off, when I run the self-diagnostic (trip reset hold, key on, release trip reset), after the firmware version (3.1), it lists the number 319468, then "no faults" before checking or setting all of the guage calibrations, when it is all said and done, the check engine light stays on. I have left the battery disconnected over the weekend, preformed the "adaptive memory reset" suggest by a member in a previous thread, all to no avail. Any recommentations or help would be greatly appreciated!
Greg
Gunkel is offline
post #2 of 12 Old 05-06-2006, 08:16 AM Thread Starter
Gunkel
Gunkel's Avatar
Bump...any ideas anyone? if not, I believe I will be headed for the dealer next week. I have checked everything I can think of.
Thanks..
Gunkel is offline
post #3 of 12 Old 05-06-2006, 08:26 AM
TAMUJeep
TAMUJeep's Avatar
sorry I'm not gonna be any help but I am having the same problem. Your not alone. I too am headed for the dealer...engine light + resr main leaking + AC not cold + 33K on an 04 = dealer trip!
TAMUJeep is offline
post #4 of 12 Old 05-06-2006, 09:45 AM
Katch
Here's the solution
On my '02 TJ, that method of diagnostics only checks the diagnostics of your dashboard (it's probably the same on newer models). You need to plug in a diagnostic code reader thing to the plug below the steering wheel (it's the rectangular looking thing). No worries though....it's easy to do and it's free.
Go to an AutoZone store (others may do it too?), and they will let you borrow their reader for free. Just let them hold on to your driver's license. Just take it out to your Jeep and plug it in...and follow the instructions. It also lets you reset the codes. Some readers may only give you a number, but you can find what it means here on the net.
Steve
Katch is offline
post #5 of 12 Old 05-06-2006, 02:24 PM
plumcrazy
plumcrazy's Avatar
got my code reader from harborfreighttools.com it also resets it for ya
i think i paid like $42 delivered
'01 Sahara, OME 2.5, 1" BL/MML, 33x12.50x15 BFG A/T tires on Aluminum American Racing rims, XM radio.
NOW i gotta figure out how to get more HP ! ! !
plumcrazy is offline
post #6 of 12 Old 05-06-2006, 03:35 PM
otisdog
2008 WK
On my 03 with the 4.0 I turn the key on and off three times to get the engine codes.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #7 of 12 Old 05-06-2006, 10:45 PM
Katch
Jim
Has your check engine light come on? Have you actually gotten any codes other than the "no fault" code? I thought that with my '02, but the key turn test on the newer Jeeps only check the dash board. If yours goes through the cycle where each guage reads from 0 to max and all the dash lights cycles, then yours also does only the dash checks. You'll find out (if you buy the $100+ service manual) when your check engine light comes on the first time. I used to think the same thing on my '02 (4.0 L), until I got the famous emission leak problem.
Steve
Katch is offline
post #8 of 12 Old 05-07-2006, 12:39 AM Thread Starter
Gunkel
Gunkel's Avatar
Thanks everyone for the replies, I will head to autozone on Monday.
Gunkel is offline
post #9 of 12 Old 05-07-2006, 07:18 AM
builderpaul
Turning off the light will do no good if you don't fix the reason it came on. As soon as you turn the truck back on it will detect the fault and turn the light back on again. Scan for the code and fixing the problem is the only way to keep the light off.
FYI: some codes are set with different driving cycles. Some will set upon the first fault detection some may need the fault detected several times before setting a code. A code reader will only read and delete the code. This can make diagnosing an intermittent problem difficult. A scanner is not much more money, it will also read pending codes and freeze frame data (what was happening when the code was set). This makes it easier to figure out those intermittent problems.
Just like an old school mechanic having to add a set a metric stuff to a tool box, todays mechanic must also have a toolbox of electronics diagnose equipment.
builderpaul is offline
post #10 of 12 Old 05-07-2006, 07:26 AM
sledog
2002 Jeep Wrangler Sport; I had the same problem; the engine light came on; and i added a can Heet; which absorbed the moisture; thus the engine light went off and has stayed off. You might try that.
sledog is offline
post #11 of 12 Old 05-07-2006, 07:28 AM
sledog
engine light
xxxxxxxxxxxxxxxxxxx
sledog is offline
post #12 of 12 Old 05-07-2006, 07:45 AM
otisdog
2008 WK
Steve
Yes - I had the check engine light come on and did the key three times thing. It displayed P0123 which turned out to be the TPS crapping out.
jim
otisdog is offline
Is there a way to reset "check engine" light? wildbadbill YJ Wrangler Technical Forum 8 05-01-2009 11:56 AM
engine light reset? jeepster4.0 TJ Wrangler Technical Forum 4 03-27-2007 06:23 PM
Check Engine Light Reset Procedure WORKS! YEA! Overdrive TJ Wrangler Technical Forum 11 12-16-2006 10:28 PM
How to Reset the computer (Check engine light)? BNovak TJ Wrangler Technical Forum 3 06-27-2004 03:54 PM
Check Engine Light reset skatedork TJ Wrangler Technical Forum 16 06-19-2003 09:59 AM
