Check Eng light on after Cold airitnake install - JeepForum.com
post #1 of 9 Old 09-16-2008, 08:41 PM Thread Starter
sfr119
Installed a Brute Force 2 cold air intake, put temp sensor in new intake hose and my check engine light is still on. Any suggestions? New to all this by the way, thanks for your help and patience.
Damon
sfr119 is offline
post #2 of 9 Old 09-16-2008, 08:47 PM
Avian
Was the light on before the install? Whats the code?
Id bet the 'puter is confused with the excessive amount of air the engine is getting.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #3 of 9 Old 09-16-2008, 09:31 PM
ptowntj
ptowntj's Avatar
Try disconnecting the battery for 15 min...I believe the computer will then reset itself and make up for the additional airflow.
8 lug xj.
ptowntj is offline
post #4 of 9 Old 09-17-2008, 06:28 AM Thread Starter
sfr119
The light came on after the install. Again, I'm new at all this, so I originally didn't hook the sensor back up. When I did realize I should hook up the sensor, the light remained on. It has been suggested to disconnect the battery for 15 minutes and the puter should reset. I appreciate the quick reply and suggestions.
Thanks, Damon
sfr119 is offline
post #5 of 9 Old 09-17-2008, 06:29 AM Thread Starter
sfr119
Thanks for the battery suggestion ptown.
sfr119 is offline
post #6 of 9 Old 09-17-2008, 06:31 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
this wont work, check the last page of my build thread (signature) for proper instructions
My builds:
and
or follow us on
spyder6 is offline
post #7 of 9 Old 09-17-2008, 06:32 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
theres are your problem. go back to the stock intake.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 9 Old 09-17-2008, 06:40 AM
spyder6
spyder6's Avatar
2010
lets try and not make this a stock vs CAI argument K? can we just help him fix this problem?
My builds:
and
or follow us on
spyder6 is offline
post #9 of 9 Old 09-17-2008, 07:03 AM
Best4x4
Get the code of the Check Engine Light first and see if it really does have something to do with the CAI. Maybe while you were installing it you accidentally un-plugged something else.
Best4x4 is offline
Check Engine Light and cold weather?? Mickeymouse YJ Wrangler Technical Forum 15 01-04-2009 02:52 PM
Cold Starting Check Engine light woody59 YJ Wrangler Technical Forum 0 02-23-2008 07:37 PM
Does the Check Engine Light Lock In? On after Lift SYE/CV install. Steve and Will TJ Wrangler Technical Forum 2 02-15-2007 09:06 PM
snorkel install, now check engine light is on ? TJ_with_Tusks TJ Wrangler Technical Forum 16 01-12-2007 12:55 PM
95 YJ 2.5L - Check Engine Light on when starting cold gary1 YJ Wrangler Technical Forum 7 02-03-2006 07:10 PM
