cheap upgrade for DANA 30 axle shaft - JeepForum.com
post #1 of 4 Old 07-18-2006, 07:53 AM Thread Starter
barry1me
barry1me's Avatar
Hey guys I came across this auction when I was looking for axle shafts for my CJ...no good for me but good for you guys!!
HD Dana 30 Axle shafts
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #2 of 4 Old 07-18-2006, 08:01 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That's a standard axleshaft for a TJ. It's older YJs that used the 260 u-joint where that axle would be a slight upgrade, though the real strength would only be from the bigger 297 u-joint. And even then, a YJ owner would have to remove the axle disconnect system on the passenger side to install them on both sides. Thanks anyway.
Jerry Bransford is online now
post #3 of 4 Old 07-18-2006, 08:30 AM Thread Starter
barry1me
barry1me's Avatar
Well thanks for the education, I thought I would try and help out my TJ Brethren with a good deal
Sport TJ build
barry1me is offline
post #4 of 4 Old 07-18-2006, 08:34 AM
Jerry Bransford
Administrator
And we appreciated the thought, don't be a stranger here! If I could afford a second Jeep, you can bet it'd be a CJ! CJs are the classic Jeep, that is for sure!
need to upgrade front axle for cheap yjman8 YJ Wrangler Technical Forum 2 11-26-2008 08:25 PM
Axle Shaft Upgrade? jeff83 TJ Wrangler Technical Forum 13 11-06-2008 04:46 PM
Looking for HD Dana 30 axle shaft upgrade - need part number Mark_ZZ3 YJ Wrangler Technical Forum 5 02-04-2006 11:57 PM
outer axle shaft, where to get used or new for cheap? Muddeprived TJ Wrangler Technical Forum 4 05-19-2005 05:14 AM
cheap axle upgrade anyone? river rat TJ Wrangler Technical Forum 10 09-28-2004 12:03 AM
