Quantcast cheap tj build up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > cheap tj build up
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 04-05-2009, 10:27 PM   #1
natgeartj
cheap tj build up
alright guys, im 16, in highschool adn have a 98 tj 6cyl 5 speed
i got it with a 2.5 inch lift with procomp shocks adn 33x12.50s
the guy doesnt know what kind of lift it is
i want the cheapest way to run 35s from this point. any help?
natgeartj is offline   Reply With Quote
Old 04-05-2009, 10:30 PM   #2
rubidriver
rubidriver's Avatar
To do 35's right it will take more than just a couple grand. Save the worries and stay at 33's.
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 04-05-2009, 10:30 PM   #3
smithtime09
theres about fifteen billion threads on here you can read to answer that question
start here
http://www.jeepforum.com/forum/f22/
smithtime09 is offline   Reply With Quote
Old 04-05-2009, 10:36 PM   #4
AcidRainCheck
well look around on the forum but you need to figure out what axles you have what gears, how you want to go about doing it, low center of gravity or more lift take your time don't make decisions you wish you didn't read reviews decide what you need for what your going to do if its any help im working towards a 2 inch old man emu diy high line d 60 rear 44 front 4.56 gears building my own long arm and 35s.
jeeps are the farthest thing from cheap
Just Empty Every Pocket
AcidRainCheck is offline   Reply With Quote
Old 04-05-2009, 10:54 PM   #5
breckboarder55
You could add a 2" BL (not cool), or a 1" BL (cooler) and tube fenders. Or a high line lift.
You will want to check out something like the Currie HD steering setup if you wheel it, and do some kind of brake up grade if you drive it on the street allot. (vanco) You will at least want to have a D44 or 8.8 in the rear. You can probably get by with out re-gearing but you will want to regear. (expensive) Otherwise your mileage, and power will suffer tremendously.
You could be really cheap and not do any of the above... but You will face breakage, and drive ability issues.
Start by finding out if you have a D44 rear axle or a D35. If you have a 44 it will save you quite a bit of money if you plan on running 35" tires.
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
02 Toyota Celica GT-S-DD/beater
breckboarder55 is offline   Reply With Quote
Old 04-05-2009, 11:18 PM   #6
KKiowaTJ
Tube fenders and you will be fine, Or trim your own and make some tube framed ones, I did and alot cheaper. For what i was going for, They suit me best. Like said though, Stick with 33's, Cheaper to replace too, And most of your parts have to be up-graded to be able to run 35's. You can get away with running them on the road, But off-road something will give quick. Just my opinion, Good luck
Couple TJ's and a XJ
KKiowaTJ is offline   Reply With Quote
Old 04-05-2009, 11:24 PM   #7
Greg_Volkman
why do you want 35's anyway?
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Old 04-05-2009, 11:41 PM   #8
97casteeltj
sawzall's help out A LOT
needing a new rig....
97casteeltj is offline   Reply With Quote
Glock Forum
