cheap fog lights - Page 2 - JeepForum.com
post #16 of 61 Old 02-07-2006, 07:39 PM
TJgreg
TJgreg's Avatar
Originally Posted by mferrari
How is the light output? Looking for some to go on my new windsheild mounts
you wont want fogs on the windshield, you'll want a projection pattern. Such a som kc 150's
Semper Fi
TJgreg is offline
post #17 of 61 Old 02-07-2006, 08:06 PM
05RedRME
those look good
05RedRME is offline
post #18 of 61 Old 02-07-2006, 08:07 PM
toates89
1989 XJ Cherokee
how easy was it to install them
toates89 is offline
post #19 of 61 Old 02-08-2006, 10:33 AM Thread Starter
markc522
pretty easy. took me about 30 min.
the mounts came with 3/8" bolts and they wouldnt fit in the holes already in the stock bumper, so i bought 5/16 carrier bolts with lock washers and nuts. perfect fit.
other than that very easy. there is a main hole in the tub where 90percent of the electrical wires come through, just below that there is a drain plug. i put a hole in it and that is where i ran the hot wire.
wireing
ground - i scratched the bumper where you could see metal and ran the ground right under the lights themselves.
hot - i ran the passanger side hot wire through the bumper to the driverside and then ran both of them into the engine compartment, where i tied them together.
then i ran the single wire inside to the 'on' side of the toggle. then ran a wire from the 'off' side of the toggle to the fuse box. i put in an inline fuse just before the fuse box, and pluged the wire into the rear wiper. (that was a blank for me)
they only come on when the key is on so i wont forget and leave them on and kill the battery.
2003 wrangler x
somewhere around a 4" frakenlift -
33" claws - black soft 8's - dt8000's - disco's
yellow jeep club member #874
JEEP:
markc522 is offline
post #20 of 61 Old 02-08-2006, 10:37 AM Thread Starter
markc522
i agree.
i would put some nice kc's on my window.
the only reason i went cheap on the bumper is i plan on messing them up.
im not sure what the light output is, all i know is that they are about 30-40percent brighter than the head lights.
2003 wrangler x
JEEP:
markc522 is offline
post #21 of 61 Old 02-08-2006, 11:34 AM
RafterTJ
RafterTJ's Avatar
wireing
Could you have tied both ground wires together and ran them to the headlight ground instead?
There was a single 'hot wire' for each light plus a single ground wire for each light?
Did you splice the two 'hot wires' together, run it to a switch, out of the switch, then run it into an in-line fuse?
What kind of fuse?
Did you run a single wire out of the in-line fuse into your fuse box?
How did you 'plug' the line into your empty fuse slot?
What empty fuse slots would be applicable for the light?
RafterTJ- '98 TJ Sport 5 speed, OME 2.5" lift, JKS 1.25" BL, JKS MML, JKS Swaybar "Quicker" discos, 15x8 Cragar Steelies, 33x12.5 BFG A/Ts, Custom Front Bumper
RafterTJ is offline
post #22 of 61 Old 02-08-2006, 12:15 PM
newbomb
newbomb's Avatar
2014 JK Wrangler
I'm holding out until these go on sale!!!!!
Former Jeeps
2001 Silver TJ
Rusty's 3" lift
33x12.50 BFGs on MT classic II's
Flowmaster 50 Delta Flow
Rusty's Airtube w/ K&N filter
Sirius Satellite Radio
Stebel 139dB Air Horn
1989 Blue YJ w/ TJ Body
2" BL
31x10.50 LTXs
Cab Top
newbomb is offline
post #23 of 61 Old 02-08-2006, 12:22 PM
02jeepman
similar set up
I've been running a similar setup to this for awhile. I gotmy lights for around 27 at wal-mart. They are more oval shaped though, and come with a plastic gaurd. I mounted mine in the middle of the bumper(surprisingly not bashed yet). The install was a little more involved with fitting the nuts and studs around the front frame tube. I wired mine in a similar fashion.
The brand was BAJA I believe, but they are frickin' bright...
PS nice work
2002 Wrangler X: 4.0/5 spd
Rusty's 2" coils, MT classic II's,
31x10.5r15's- Cooper Discoverer S/T's, K&N, Removed "X" stickers, removed floatation devices
02jeepman is offline
post #24 of 61 Old 02-08-2006, 12:28 PM
DrD
DrD's Avatar
just picked up my hellas 500 fogs. total cost $80.61. Hopefuly wont have problems with installation. Will post some pics when I'm done.
RED JEEP CLUB MEMBER #344
2k2 TJ X
it's not your average grocery-getter...
3.07 GEAR CLUB MEMBER #14
polish jeep owner club member # 15
DrD is offline
post #25 of 61 Old 02-08-2006, 01:51 PM Thread Starter
markc522
QUESTIONS AND ANSWERES
IM NOT THAT ELECTRICALLY INCLINED BUT I DONT SEE WHY NOT.
YES
YES. THEN FROM THE INLINE FUSE TO THE FUSE BOX (FUSE LABELED 'REAR WIPER')
What kind of fuse?
ONE SIMILAR TO THIS (I PUT IN A 12 AMP)
YES
WITH A FITTING LIKE THIS. (SECOND FROM THE BOTTOM ON THE LEFT)
YOU WILL HAVE TO GET A TEST LIGHT AND SEE WHICH WORKS WITH THE KEY ON.
EXAMPLE - THE 'SUB WOOFER' FUSE ON MINE WORKED WITH THE KEY ON AND OFF.
THE REAR WIPER WORKS WITH THE KEY ON ONLY.
DEPENDS ON YOUR OPTIONS I SUPPOSE.
2003 wrangler x
JEEP:
markc522 is offline
post #26 of 61 Old 02-08-2006, 02:01 PM
RafterTJ
RafterTJ's Avatar
Thank you very much for the reply. I appreciate it.
Would Radio Shack be a place for the fuse and switch or Autozone?
RafterTJ is offline
post #27 of 61 Old 02-08-2006, 02:08 PM Thread Starter
markc522
I HAD THE INLINE FUSE LAYING AROUND SO I DONT KNOW WHERE TO GET IT. I THINK A PARTS STORE WILL HAVE MOST OF WHAT YOU NEED.
IM SURE RADIO SHACK WILL HAVE IT ALL TOO. (I HAVENT BEEN IN A RADIO SHACK FOR YEARS)
YOUR IN ARLINGTON RIGHT? NORTHERN TOOL IS ON 20 JUST EAST OF 360. (I THINK ITS THE GREATER SOUTHWEST PARKWAY EXIT)
2003 wrangler x
JEEP:
markc522 is offline
post #28 of 61 Old 02-08-2006, 02:29 PM
FromHereDown
did u use a wiring hareness of somekind?
how did u wire them into the fuse like that?
im looking to add some foglights but im a complete noob @ wiring
FromHereDown is offline
post #29 of 61 Old 02-08-2006, 02:31 PM
RafterTJ
RafterTJ's Avatar
re-read his post- it has the info about how to wire it.
It looks like he just tie-wrapped the wires and fished them through the firewall to me- no wiring harness
RafterTJ is offline
post #30 of 61 Old 02-08-2006, 02:33 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
With that much current it would be a good idea to run off a relay. That way the current doesn'y go through the switch, I melted one that way. And the power would go straight through the relay to the lights. Not having to go through the cab and back out could make them a tad bit brighter and your dash less likely to ignite. They look great though.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
Cheap Lights f1rocco JK Wrangler Technical Forum 21 09-25-2009 03:33 PM
cheap set of lights sappi285 YJ Wrangler Technical Forum 9 11-17-2008 04:15 PM
ebay vs q-tek cheap fog lights Red Rubycon TJ Wrangler Technical Forum 8 07-17-2006 12:05 PM
cheap lights! gtex TJ Wrangler Technical Forum 12 11-10-2005 03:01 PM
Rock lights on the Cheap geauxturbo TJ Wrangler Technical Forum 14 01-17-2005 12:27 PM
