Cheap but good way to extend sway bar links?... - JeepForum.com
post #1 of 21 Old 03-16-2012, 09:21 PM Thread Starter
05Unlimited
I just bought a lightly used OME 2.5" HD set of shocks and springs. I also got an RC relo bracket for the rear track bar. Since one of my big goals is to keep my lift simple and inexpensive I have no interest in quicker discos and just want to extend my front and rear links enough to match up properly with the lift (same amount as lift I assume).
Anyone have suggestions on inexpensive links that are longer? Or has anyone cut and welded in round bar metal to extend them (I'd have to pay for that so probably not a good option for me)?
If anyone has used stuff they want to part with let me know.
I am not going to use adj track bars but simply relocate the front and rear stockers, as I've read their clearance is usually better for full articulation than the beefier aftermarket adj bars anyway (plus this is my one and only lift since it's my DD ...won't be going higher other than adding BL/MML later on, if even that).
Thanks for any info or good used parts anyone can sell.
2005 LJ, NSG-370 6-spd (close-ratio), 3.73's, three tops incl. custom Sunrider-Safari top, 38"x22" hardtop sunroof, OME 2.5", JKS 1.25 BL/1.0 MML, seats 2"^, 285/75/16 Duratracs, Ion 171's (16x8), Alpine CDE135-BT/KTP-445/Polk521Db/650Db, full soft/hard doors, Harley L.Stms, "I swear my Jeep is staying stock"
05Unlimited is offline
post #2 of 21 Old 03-16-2012, 09:41 PM
hustler905
Do you want cheap or good? I find it's one or the other.
hustler905 is offline
post #3 of 21 Old 03-16-2012, 09:56 PM
stokerdog
I cut the links and welded in an extension. Cheap and Good
"If a law is stupid, you have to break it."
HST
stokerdog is offline
post #4 of 21 Old 03-16-2012, 10:58 PM
cheapjeep06
The stock links are 1/2". I used 3/4" round stock, drilled 1/2" holes, about 1" deep, made them 5" longer than stock. Heated and bent to exact shape. Took stockers and cut off ends, leaving 1" on each to insert into new link extention. Installed with slip-fit loctite, then drilled and installed roll pins to secure ends. Makes stockers 3" longer for lifted applications. (Yes, I was bored at work one day...).
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #5 of 21 Old 03-17-2012, 08:01 AM Thread Starter
05Unlimited
Since I can't weld I just thought of a potential option that's probably better anyway. Perhaps use some 3/4" round stock and drill 1/2" holes in it, then tap the holes. Cut matching threads into one of the cut pieces of stock link. Then you have homemade adjustable extension links. Only thing I don't know how to do is cut outer threads onto the 1/2 stock links (I imagine it's easy but I've just never cut ...only tapped).
How's this for an idea?
OTOH I have some pending deals for good used stuff like some Fabtech rear swaybar end links ~25 shipped? Tempted to save time and just do that ....
post #6 of 21 Old 03-23-2012, 09:10 AM Thread Starter
05Unlimited
I have run out of patience researching this (for some reason it's mysteriously hard to find any info via search and also hardly anyone makes the proper length fixed end links for a 3" lift). HOWEVER, I stumbled on this and it's obviously reasonable (Fat Bob Zone 3" deal):
http://fatbobsgarage.com/i-7189735-j...ink-combo.html
Would this work well? Why aren't the front links offset like stock? ...won't that cause a problem? Maybe not since there is a bushing at each end. LOL if you do a search on "length of stock TJ front sway bar links" you will come up with NOTHING LOL, NOTHING!!! I'm just going to go measure mine ....sheesh. I know the rear is a good length because rear links are 7" eye to eye and Zone's 3" is 9.75" so 2 3/4" is acceptable and should plant it a tad tighter IIUC. Fronts ....who knows, it's a mystery one must get the measuring tape out for lol.
post #7 of 21 Old 03-23-2012, 09:13 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
You can buy extended solid links on ebay.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #8 of 21 Old 03-23-2012, 09:34 AM Thread Starter
05Unlimited
Thanks Boog' ....I've already looked a bit but only found a deal that's about the same as Bob's Zone kit. What do you think about the issue of (at least the links actually pictured) the links not being offset like stock? Also note that the front links in the Zone 3" kit are only 9" and stock is about 7 - 7.5" from what I just measured. I wonder why they didn't make their fronts 10" long? Perhaps they found a slightly reduced sway bar angle to be better than stock?:
"Vehicle Applications:
1997 2006 Jeep Wrangler TJ 3 Lift
Kit Contains:
- Front sway bar end links for 3-4 of lift (9" Length) - stock is 7 - 7.5" so this seems inadequate? Maybe when you add the extra length of the adaptor-brackets it nets out to 10"?
- Rear sway bar end links for 2-3 of lift (9.75" Length) - stock is 7" so this seems good
post #9 of 21 Old 03-23-2012, 11:31 AM
TheBoogieman
Kit Contains:
All the aftermarket front links mount slightly differently.They mount the same but the top link has the extra top mount(like rear links with a top mount piece).The exact length of the links isn't really important.Most go from 0-2" lift and 2-4" lift.Anything is better than the stock front,easily breakable ones.I need new front ones myself for a 2" lift.
post #10 of 21 Old 03-23-2012, 11:44 AM Thread Starter
05Unlimited
Yeah that's the only reason I'm discarding the idea of extending my stock links ...too much time and work for something that's not very strong. My stock rears aren't even steel, they're like a tough kind of plastic or something. I figured that out about the top link but that still doesn't address the geometry problem with having a straight link vs an offset one. Seems like exact length would be kinda important, not critical of course but pretty important to achieve the optimum sway bar angle (about 10 degrees).
post #11 of 21 Old 03-23-2012, 11:48 AM
TheBoogieman
The aftermarket ones aren't straight.The actual bends are at the top and bottom mounts where the bolts go through.It's not as obvious,but you'll know if you install them wrong.
post #12 of 21 Old 03-23-2012, 12:03 PM Thread Starter
05Unlimited
I thought I could maybe see a slight angle at the ends, hard to tell from pics. Thanks. I think I'll just go with Fat Bob's stuff ...pretty solid deal on solid links ...
post #13 of 21 Old 03-23-2012, 12:07 PM
TheBoogieman
post #14 of 21 Old 03-23-2012, 12:27 PM
NotURMailman
NotURMailman's Avatar
I wish someone could coherently explain why everyone seems to think that the sway bar cares at all what angle it is mounted at. If the tires don't hit it, and the links are equal length, what difference does everyone think it makes?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #15 of 21 Old 03-23-2012, 12:32 PM
vtx531
I cut mine extended ones and welded them shorter so it should work if you did the opposite! That's how they make them anyways...
vtx531 is offline
Sway Bar and Sway Bar Links -- MOOG? mmitsch TJ Wrangler Technical Forum 9 08-09-2009 11:21 PM
Cheap ways to extend bumpstops idgit0488 TJ Wrangler Technical Forum 9 11-16-2006 07:45 PM
Sway Bar links 98kkk TJ Wrangler Technical Forum 2 08-02-2006 08:22 PM
Are CJ and TJ sway bar links the same? ponq TJ Wrangler Technical Forum 2 03-26-2005 01:55 PM
RE sway bar end links chadjeep TJ Wrangler Technical Forum 2 08-26-2004 08:30 PM
