Charging Woes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Charging Woes
Rampage Bowless Soft Top Oconee offroadAlloy USA Still AvailableAdvance Adapters SYE Kits
Unread 08-30-2014, 11:00 AM   #1
ihavenoidea
Charging Woes
Last week my original alternator went, or so I thought. The battery gauge started reading 19+ and it eventually killed the battery.
So I replaced the alternator and battery. Still having charging issues.
When I left work, the battery gauge was dead. As I got closer to home, everything started to dim so I pulled over. The idle dipped very low as if it was about to stall then came back up to normal idle and the gauge read 14V and I confirmed this with a multimeter.
This morning I started it up and the alternator wasn't putting any voltage out, the multimeter only read 12.2V at the alternator post. I pulled the alternator and had it tested. Tested fine.
What to check next? 97 4.0L TJ
ihavenoidea is offline   Reply With Quote Quick reply to this message
Unread 08-30-2014, 07:19 PM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Check and see if the fusible link is corroded or loose?...
Edit: Or signs of it having been hot...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 08-30-2014, 08:17 PM   #3
Dave02TJ
Dave02TJ's Avatar
Do as Knucklehead suggests, but just a heads up for you, the voltage regulator is part of the PCM - Powertrain Control Module.
Dave02TJ is offline   Reply With Quote Quick reply to this message
