Quantcast Changing trans fluid, NSG370 (6-Speed, '05) - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Changing trans fluid, NSG370 (6-Speed, '05)
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGSALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30
Old 11-06-2009, 10:50 PM   #31
TheHeretic
TheHeretic's Avatar
Originally Posted by glockster View Post
$2399.99 pg 289 of the Holiday Edition Quadratec mag. Brand new, not remanufactured. Rediculous in my book.
JB weld it or something.
I was thinking of JB Weld, but that isn't a long term solution, I don't want to be constantly worrying about it failing, know what I mean?
If the housing part that has the crack can be replaced, then that would be okay, it needs the throw out bearing replaced anyway.
VA3IPB
OBAMA !
TheHeretic is offline   Reply With Quote
Old 11-06-2009, 11:20 PM   #32
rubidriver
rubidriver's Avatar
Originally Posted by beemerd View Post
Well guys, it says ON THE BOTTLE that it meets MS-9224. If its there I will assume it meets the standard.
Now, I have sweating on the drain plug, how do I fix that?
Can you take a picture of that? Im almost positive it still says recommended.
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 11-06-2009, 11:27 PM   #33
TheHeretic
TheHeretic's Avatar
AMSOIL Synthetic Synchromesh Transmission Fluid (MTF) is recommended for automotive and light truck applications that require synchromesh transmission fluid. Applications include manual transmissions and transaxles such as New Venture NV T350, NV 1500, NV 3500, NV 3550, NV 5600 and Tremec T-4, T-5, T-18, T-176, T-500 and T-600. Replaces Honda Genuine MTX Fluid for manual transaxles. MTF is an SAE 5W-30, however, it is not for use in engines or wet clutches.
AMSOIL Synthetic Synchromesh Transmission Fluid (MTF) replaces GM part # 12345349, 12345577, 12377916 and 1052931 as well as Chrysler part # 4874464 and 4874465. It meets GM specifications 9985648, 9986105 and 9985535 and Chrysler MS-9224 and MS-9417.
Synthetic Synchromesh Transmission Fluid for MOPAR 5 speeds
From this website.
VA3IPB
OBAMA !
Old 11-07-2009, 03:00 AM   #34
rubidriver
rubidriver's Avatar
From this website.
AMSOIL - Synthetic Manual Synchromesh Transmission Fluid (MTF) show me where it says it meets or exceeds the 9224 spec on the bottle or this webpage. Lumpsteer has done the research, it does not M/E the 9224 spec.
Old 11-07-2009, 03:54 AM   #35
TheHeretic
TheHeretic's Avatar
The bottles I have say it meets the spec. The website also says it meets the spec.
VA3IPB
OBAMA !
Old 11-07-2009, 07:28 AM   #36
Ridin' Around
Wanna Go Along?
Ridin' Around's Avatar
Ridin' Around is offline   Reply With Quote
Old 11-07-2009, 07:56 AM   #37
GroundAssault
2006 Jeep Wrangler---SOLD!
Nowhere at present is there such a measureless loathing of their country by educated people as in America. --Eric Hoffer
Originally Posted by rmb2485
cheap mods are like a drug dealer giving you your first few for free...they will only get you addicted and before you know it every paycheck goes into your new habit :rofl:
GroundAssault is offline   Reply With Quote
Old 11-07-2009, 07:57 AM   #38
GroundAssault
Yay! Double post
Old 11-07-2009, 08:59 AM   #39
lumpster
lumpster's Avatar
You broke your tranny changing oil, im not trying to be mean, but i doubt you can swap all the guts from the tranny into another one.
I would take it a shop if i were you.
Originally Posted by SuperWade2 View Post
Blaine asked me before we left camp if I'd ever been wheeling before, I said "sure, of course I have"... about 50 feet onto the trail, he said "Wade, you f'in lied to me, you've never been WHEELING before"... I think he was right! :rofl:
Want to STOP?
JEEP Co-op parts, jk, tj, lj, yj, cj delrin door bushings, TRE inserts, poolball shifters, tierod flip kits
My Goodyear tire experience
lumpster is offline   Reply With Quote
Old 11-07-2009, 01:10 PM   #40
rubidriver
rubidriver's Avatar
Are you sure? Me and Lumpster had a lil arguement over this. He was saying Amsoil "does not meet or exceed" because of wording. I was saying that Amsoil might have there wording wrong and that I didnt know if it met or exceeded the spec:
http://www.jeepforum.com/forum/f9/royal-purple-trans-fluid-776772/
Read the whole thing, but pay close attention to post 72 on page 5. Amsoil does NOT meet or exceed the OEM spec.
Old 11-07-2009, 03:38 PM   #41
alex211
You don't have to torque tapered pipe threaded plugs. Just a wrap of some Teflon tape and then snug it down is all.
2003 Rubicon
3" Zone lift, 1.25 body lift, 1" MML, 33" MTZs
alex211 is offline   Reply With Quote
Old 11-07-2009, 06:49 PM   #42
tlendt
Am I missing something? How about TIG welding the crack? No harm in trying and CHEAP. (Let someone else do the welding)
tlendt is offline   Reply With Quote
Old 11-07-2009, 07:04 PM   #43
TheHeretic
TheHeretic's Avatar
The problem with TIG welding is not knowing the base material is made up of. It's aluminum, but what grade? Plus TIG welding auld mean dropping the transmissin anyway, plus the. *** would have to be cleaned so I could get a good bead... It's a good idea, don't get me wrong, but a repair like thatwould not last very long, without knowin the exact composition of the aluminum. It's probably, loaded with magnesium which makes aluminum welding difficult.
VA3IPB
OBAMA !
Old 11-07-2009, 07:25 PM   #44
frontlinedude
if you replaced the whole tranny because of this, thats like replacing the whole jeep because of a little scratch. just drain the fluid into something clean. Just JB weld up the crack and call it good, If people fix cracked engine blocks with JB, Im sure you wont have a problem. Then put your still pretty new fluid back in and torque to spec
'97 BLACK TJ Sport
4.0L 5 speed Man.
4in lift
35"x13.5 Toyo Open Country M/T
Herculined
frontlinedude is offline   Reply With Quote
Old 11-08-2009, 07:31 PM   #45
TheHeretic
TheHeretic's Avatar
HOLD ON! I was looking at my Jeeps tranny, and noticed that the part of the transmission where the drain and fill plugs are is bolted in at both ends to the rest of the transmission. Would they not be able to just pull that section out, and replace with new?
VA3IPB
OBAMA !
Glock Forum
