Changing trans fluid, NSG370 (6-Speed, '05)
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full |
#1 | |
I changed the fluid in the NSG370. I think I messed up though; it can't be THAT simple to do. I waited until fluid was coming out of the fill hole. The fluid that came out didn't look dirty. The drain plug magnet was full with shaving though.
VA3IPB OBAMA ! |
#2 |
TITS
Yeah, it's that simple. Drain, refill. It's normal to see some shavings on the magnet. No worries.
#3 |
What did you use for replacement, aftermarket or Mopar?
#4 |
I have a 05 Wrangler with same trans,it has 78,000 miles when i changed the fluid..I had a few shavings also..I put in Amsoil manual trans fluid and it seems to shift better,but my buddies say for the price of Amsoil it better shift its self....
Buford |
#5 |
I used Amsoil, Synchromesh. I chose this over the Redline, only for the fact that the Amsoil meets MS-9224.
VA3IPB OBAMA ! |
#6 | |
No kidding about not cheap though; $14 per quart here in the Great White North.
VA3IPB OBAMA ! |
#7 |
Lets not get into this discussion. Amsoil does NOT meet or exceed. Its recommended.
#8 | ||
In the end i bought RP Synchomax and it shifts better with that stuff that the factory fill so im happy
Want to STOP? JEEP Co-op parts, jk, tj, lj, yj, cj delrin door bushings, TRE inserts, poolball shifters, tierod flip kits My Goodyear tire experience |
#9 | |
Now, I have sweating on the drain plug, how do I fix that?
VA3IPB OBAMA ! |
#10 |
Bolt-on Maniac
Are you sure its not just a little bit of leftover oil residue on the plug?
#11 |
Should I have installed a new drain plug with the new trans fluid?
VA3IPB OBAMA ! |
#12 |
spray the drain plug and fill plug areas with brake or contact cleaner, should get rid of any residual oil
#13 |
It still leaking.
VA3IPB OBAMA ! Last edited by TheHeretic; 11-09-2009 at 03:30 AM.. |
#14 | |
no offense, but its one of the easiest jobs to do, like changing motor oil. get a new torque wrench and recheck it.
#15 |
this might sound stupid and i don't even know if it's possible but, i seem to remember that you need 2 differnet sized hex sockets to remove these plugs, could you have mixed them up when insatalling them?
if the plugs are in the correct spot, i would remove the drain plug (drain oil in to a clean container so you can refill your trans.) and inspect the threads for damage ex. cross threading, as well as the threads in the trans. wrap teflon tape around drain plug threads and reinstall, i know the fsm says 22 ft lbs but it is just a drain plug to keep oil in, i am sure a little less torgue will be fine |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
