Changing a starter - JeepForum.com
post #1 of 8 Old 07-22-2010, 10:21 PM Thread Starter
nuclearstrife
Changing a starter
My starter has stopped working properly since my last run out. I have to hit it with a hammer to get it to turn over.
With that being said, is there anything I need to be aware of when changing the starter? Looks like disconnect the battery, disconnect the leads, unbolt and do the reversal for the new one.
I am going to pick up a new one tomorrow and hopefully get this in this weekend.
Any input would be helpful.
nuclearstrife is offline
post #2 of 8 Old 07-22-2010, 10:31 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Easy swap with the correct tools.
reverse torx (I think), if it is don't use at 12 point wrench as it will strip.
Group W Bench
CRAWLING 98 is offline
post #3 of 8 Old 07-22-2010, 10:31 PM
MountainMan864
My buddy did it for me in under 20 min. old one out new one in. be sure the ground strap is secured and clean the plug too. tighten the bolts good.
MountainMan864 is offline
post #4 of 8 Old 07-23-2010, 04:39 AM
zu903
did mine a week ago its very easy and i was surprised at how cheap they where
zu903 is offline
post #5 of 8 Old 07-23-2010, 06:02 AM
the_art_of_desi
Ya, make sure you have the inverted torx bit before you start...
1997 TJ SE - Emeral Green Pearl
2.5L : AX-5 : NP231, D30HP : D44 : 4:88 : Front Aussie
2.5" OME lift, OME LT shocks, 2" BL, Currie Control Arms, Currie HD Steering, Currie Trackbars, Warn M8000
Custom Front and Rear Bumpers, Custom Rock Sliders, OBA
33" x 12.5" x 15" Goodyear MTRs, Black Steelies
the_art_of_desi is offline
post #6 of 8 Old 07-23-2010, 06:15 AM
tjsooner
think they're called e-torx need an E14 i believe
tjsooner is offline
post #7 of 8 Old 07-23-2010, 06:58 AM
kennemore_m
Not sure about the 6 cyl as I have not had to do that yet but on last YJ with 4 cyl, 5 speed it was very easy. Two of the reverse torx bolts that go straight up (after disconnecting the battery cables). Once you pull the bolts the starter may seem stuck or seem like you are missing a bolt. Just give it a wiggle and it come right out. If there is a shim, try to note the position of it and install it back with the new starter (if the new starter did not come with a new one). That's about it. Took me about 15 minutes to do the last one.
chatttownjeep
kennemore_m is offline
post #8 of 8 Old 07-25-2010, 07:40 PM Thread Starter
nuclearstrife
Thanks guys for the heads up. Got it changed out in about 20 mins and I am back in business.
starter , replace , replacing , help , advice , tj , wrangler , electric
Changing a starter regionrat TJ Wrangler Technical Forum 3 09-20-2008 09:01 PM
changing the starter gribbles TJ Wrangler Technical Forum 8 05-18-2008 03:35 PM
changing the starter got_4_lo YJ Wrangler Technical Forum 13 07-12-2007 05:37 PM
Changing a starter scruffyjon YJ Wrangler Technical Forum 5 04-10-2006 03:42 AM
Changing Starter, Need Help wake5150 TJ Wrangler Technical Forum 1 05-20-2003 08:45 AM
