Changing Speedo Gear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Changing Speedo Gear
Engo winches available at www.rockridge4wd.com! Free shippFS: Wranger BRIGHT License Plate LED! Just $3! Great valuePremium LED Lighting by VISION X, Proudly sold at ROCKRIDG
Unread 08-21-2014, 07:27 AM   #1
rjlaraway
Dana 30/186MM Front Axle
3.07 Rear Axle Ratio
Dana M35/194MM Rear Axle
4.0L I6/Manual
Put 31x10.5 tires on with the existing 2" BB and noticed speedo is off, at 65 (confirmed by GPS app) it's actually 59-60 on the speedo.
Changing the gear looks pretty straight forward. I think this is the piece I need
http://www.quadratec.com/products/55200_6127.htm
Any advantage to going up or down a size here? It doesn't actually affect my gears correct? It's just a sensor for the speedo and odometer, right?
rjlaraway is offline   Reply With Quote
Unread 08-21-2014, 07:44 AM   #2
bisleywrangler
Junior Member
There is no legal advantage in making your speedo read higher or lower than it should. Changing the gear will only affect the speedo and not the actual gearing of the axles.
bisleywrangler is offline   Reply With Quote
Unread 08-21-2014, 10:44 AM   #3
treemagnet
The only thing u have done is change ur tires for larger than stock, so ur speedometer is reading faster by very little than what ur actual speed is. I would suggest not bothering to do this at this time
Wait till you decide to change ur gears to say 4.10 or 4.56 from the 3.07 then buy the correct one as now u would be paying twice for it. I did just that waited till i did my gears. As u cannot get a ticket for going
to slow normally but u can for overspeed.
2003 tj
4.11 - 6cy
treemagnet is offline   Reply With Quote
Unread 08-21-2014, 11:10 AM   #4
rjlaraway
Good point, out of curiosity what are the costs associated with going to 4.10 from 3.07?
Unread 08-21-2014, 04:22 PM   #5
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
4.0L I6/Manual
Installing a speedometer gear 2 teeth smaller would get you close, 1 tooth equals approximately 3 mph at 60 mph on your speedometer. HTH
I think you've got that backwards...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
Unread 08-21-2014, 05:58 PM   #6
2jhanna
OP, if you check out this thread below, you may can do a speedo gear swap for close to free, just shipping.
http://www.jeepforum.com/forum/f9/ta...o-gear-643981/
jhanna
denton county, tx
2jhanna is online now   Reply With Quote
Unread 08-21-2014, 07:30 PM   #7
sarkaukar2000
On the installation paperwork at the Quadratec site, a very important piece that gets missed at times.
8. You will notice that there are a series of number located
along the side of the speedometer gear housing. Select the
appropriate tooth gear range you just installed and rotate it
until it is aligned with the raised dot on the transfer case as
shown in the picture to the left.
sarkaukar2000 is offline   Reply With Quote
