Changing serpentine belt on a 2004 Wrangler - JeepForum.com
post #1 of 39 Old 12-28-2005, 12:41 AM Thread Starter
Rocky529
Rocky529's Avatar
I searched for the past 30 minutes and came to the conclusion that the tensioner is adjusted automatically on newer Jeeps. So, am I correct in saying that all I have to do is loosen the bolt on the idler pulley and that will loosen the belt enough to come off?
Thanks in advance
Here is what I am referring to:
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #2 of 39 Old 12-28-2005, 12:49 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Correctomundo. Just use a wrench on the spring-loaded automatic belt tensioner as a lever to pivot it away from the belt to relieve the tension.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #3 of 39 Old 12-28-2005, 01:35 AM
abnormal
Platinum Member
abnormal's Avatar
Just to make sure and I am not trying to insult any intelligence... you dont loosen the bolt on the idler pulley, you just turn it and the pulley will turn and pivot away from the belt.
abnormal is offline
post #4 of 39 Old 12-28-2005, 09:31 AM Thread Starter
Rocky529
Rocky529's Avatar
Thanks much... and a Goodyear belt is a good replacement?
Rocky529 is offline
post #5 of 39 Old 12-28-2005, 09:43 AM
beyondink
How do I do the same thing on a '97? Mine is squeeking like crazy.. and where is a good place to get a new belt?
There are NO Weapons of Mass Destruction in Irag!!, Chuck Norris lives in Oklahoma!
beyondink is offline
post #6 of 39 Old 12-28-2005, 09:46 AM
river rat
Forum porn star...I guess
river rat's Avatar
How do you have a bad belt on an 04? And why isn't it covered by warranty?
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #7 of 39 Old 12-28-2005, 09:50 AM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
That new of a vehicle I would bet one of the pulleys is bad. Its happened on several of my other past vehicles. It was the idler or tension pulley that was sqeaking, never been a belt.
Id take it in and have it looked at.
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #8 of 39 Old 12-28-2005, 09:57 AM Thread Starter
Rocky529
Rocky529's Avatar
Belts are cheap enough and I'd rather spend the time myself rather than taking it to the dealership right away. Worse comes to worse, I'll put the stock belt back on and take it in.
Rocky529 is offline
post #9 of 39 Old 12-28-2005, 10:00 AM
river rat
river rat's Avatar
OK, but what I'm trying to say is that if you really have a bad belt on an 04, you have problems other than a belt. A stock belt should last years and years.
post #10 of 39 Old 12-28-2005, 10:18 AM Thread Starter
Rocky529
Rocky529's Avatar
Well the squeak stops with belt dressing... but it only lasts a day.
Rocky529 is offline
post #11 of 39 Old 12-28-2005, 10:22 AM
Jerry Bransford
Administrator
It seems that every serpentine belt I have installed cautioned against using belt dressing, though I don't know why.
Getting
post #12 of 39 Old 12-28-2005, 10:23 AM
RockRunner85
You use a 1/2 drive ratchet and stick it in the square hole on the auto tensioner. Turn the ratchet and it will loosen up the belt so you can slip it off. Route the new belt around use the ratchet to loosen the tensioner and slip it back on.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #13 of 39 Old 12-28-2005, 10:24 AM
river rat
river rat's Avatar
Sounds like you possibly have a misaligned pulley or bad idler pully. Fix the problem, not the symptom.
post #14 of 39 Old 12-28-2005, 10:25 AM Thread Starter
Rocky529
Rocky529's Avatar
Is it easy to replace the idler pulley myself? It sounds like it's coming from that area.
Btw, I already have the belt off but I don't want to completely take out the bolt on the idler pulley.
Rocky529 is offline
post #15 of 39 Old 12-28-2005, 10:30 AM
river rat
river rat's Avatar
Should be a peice of cake. But I would let DC eat the cost IMO.
Serpentine belt help 1998 wrangler ble10 TJ Wrangler Technical Forum 5 11-15-2009 02:26 PM
Replacing serpentine belt on 2004 TJ DJ5 TJ Wrangler Technical Forum 4 08-22-2009 01:27 PM
Changing the Serpentine Belt on an 01 SE TJ 01amberfirewv TJ Wrangler Technical Forum 6 06-26-2008 04:28 PM
Changing serpentine belt on a 1994 Wrangler Rocky529 YJ Wrangler Technical Forum 5 07-28-2006 03:45 AM
2000 Wrangler Serpentine belt voigtrobert TJ Wrangler Technical Forum 4 10-24-2005 06:59 PM
