Changing a Rear Main Seal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Changing a Rear Main Seal
All Bilstein shocks & struts - Lowest Prices Ever and RuffStuff Memorial Day Sale!Poison Spyder to donate 10% of Memorial Day W/E Sales to R
Unread 12-27-2010, 12:45 PM   #1
Irishcopper
I'm the original owner of a 2001 Jeep Wrangler with a 4.0 engine with 81K miles and 5 speed manual transmission. I've maintained my Jeep in accordance with Jeep's scheduled maintenance and it's served me quite well. Last week I noticed some dime sized spots of oil in my carport. I checked the oil level and was down half a quart. I topped the oil level off and have been monitoring it daily. Based on where it's originating from the oil appears to be the result either a valve cover leak OR from the rear main seal. I don't have the means to work on the Jeep myself but I've found a ASE certified mechanic that has a good reputation with Jeep owners to troubleshoot the leak and make the necessary repairs. If the oil is originating from the rear main seal is there anything else I should have them replace while they have the transmission pulled? A friend suggested replacing the clutch kit and slave cylinder as they are both original. Given the majority of the mechanics bill will be for labor do you think it would wise to get all of this accomplished at once, or is it overkill? This is my primary mode of transportation and want to keep it running well and out of the repair shop! Thanks!
Irishcopper
Irishcopper is offline   Reply With Quote
Unread 12-27-2010, 12:55 PM   #2
unlimited4x4
To replace the rear main seal I believe you only need to drop the oil pan, and a few bottom engine components based on the write ups I have reviewed, not the transmission. Mine is leaking as well.
Here is a good write up:tek-tonic
05 Unlimited 4x4
I don't want to take Mommy's car. It doesn't have sky in it like Daddy's. - CJsPerson
unlimited4x4 is offline   Reply With Quote
Unread 12-27-2010, 01:01 PM   #3
Sirwriter
I'm dropping my tranny to replace it with a rebuilt one. Even though the clutch works fine, I'll put a clutch kit and slave cylinder in it simply because of the time and hassle of yanking everything out to get to it if it does go bad. Mine's not the original, but it has about 85K on it. If you have a mechanic do yours, it would cost a lot less to do it now with the tranny out than to have to go back in at a later date and do it from scratch. Mine's a 99 TJ. I'd vote to replace it now.
Sirwriter
Sirwriter is offline   Reply With Quote
Unread 12-27-2010, 01:05 PM   #4
mdm
Farm Wheeler
The transmission does not have to be removed to replace the 4.0L rear main seal. 81K is probably about half the life of the OEM clutch for most people. Replacing the clutch would significantly increase the cost of both parts and labor.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote
Unread 12-27-2010, 01:05 PM   #5
unlimited4x4
Makes sense now.
05 Unlimited 4x4
Unread 12-27-2010, 01:47 PM   #6
Sirwriter
I didn't know you could replace the rear seal that easily. In my case, I still think it is a good economic move to replace the kit while the tranny is out, since I'm replacing the tranny. Not that much more money and takes only a little while longer.
By the way, that's a very good write up!
Sirwriter
Unread 12-27-2010, 02:01 PM   #7
Lv03JeepTJ
Does this also go with automatic transmissions? 2003 Wrangler with a 6cyl. Thanks!!
Lv03JeepTJ is offline   Reply With Quote
Unread 12-27-2010, 02:07 PM   #8
mdm
Farm Wheeler
Yes.
Welcome to the forum.
Unread 12-31-2010, 10:10 AM   #9
Irishcopper
Thanks to those of you that provided me your recommendations regarding my 2001 Jeep Wrangler. The oil was leaking from both the rear main seal and valve cover gasket. As several of you mentioned the transmission DID NOT need to be removed and my mechanic only needed to pull the oil pan to change the rear main seal. This mechanic has a reputation for being honest and doing good work, but I was glad to have some insight about how to troubleshoot this leak before taking it to his shop.
Ya'll have a safe and Happy New Year!
Cheers!
Irishcopper
Unread 12-31-2010, 11:29 AM   #10
oakmckinley
oakmckinley's Avatar
I am going to bookmark that write up, its great!
Thanks for including it!
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline   Reply With Quote
Unread 01-01-2011, 11:24 AM   #11
doclouie
Here is another good write up.
http://www.savagesun4x4.com/oil_pan_...bearing_s.html
doclouie is offline   Reply With Quote
Unread 01-01-2011, 12:37 PM   #12
chris142
Before you spend the $$$ to replace the rear main check the oil pan bolts in the area near the 2 Precats. I think that the heat from them makes the bolts loosen. I've fixed 3 Jeeps now just by tightning those bolts.
chris142 is offline   Reply With Quote
Unread 01-03-2011, 07:59 AM   #13
mdm
Farm Wheeler
Sirwriter
You do have to remove the transmission to replace the rear main seal. You have the 4 cylinder which uses a one piece seal. The 6 cylinder uses a two piece seal.
Unread 01-03-2011, 08:09 AM   #14
Sirwriter
Thanks for the heads up. I'm yanking out the clutch, the tranny, and the transfer case this week. I would have wondered WTF???
Unread 12-28-2011, 03:17 PM   #15
boydbe
4.0 rear main seal
I have removed the two bolts for the rear main bearing cap and it won't budge. Any recommendations?
Thanks,
boydbe is offline   Reply With Quote
