Changing NV3550 fluid. - JeepForum.com
post #1 of 9 Old 09-06-2007, 06:56 AM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
To start, sorry guys for the beginner question. I as still young and want to learn.
Anyways, i just purchased enough RP fluids to replace everything in the jeep. I've done the motor oil, and the NV3550 is next on the list.
Where can i find some instructions on the procedure? I have the FSM for 04, but i cannot seem to locate anything about transmission fluid change.
Also are there any special tools i will need?
Thanks in advanced guys,
Kelvyn
_______
|_
_|
(OlllllllO)
Panici is offline
post #2 of 9 Old 09-06-2007, 07:14 AM
Erin Go Bragh
Erin Go Bragh's Avatar
try stu-offroad.com
he's got a write up on how to change the gear oil in a nx-15 trans. Pretty straight forward procedure and also will work just the same for your trans. Drain plug and fill plug might be in slightly different locations though.
"Some days I feel about as sharp as a butter knife."
"It's not the years, it's the mileage. "
"Common sense will take a person far in life, problem is, common sense just isn't very common anymore."
Erin Go Bragh is offline
post #3 of 9 Old 09-06-2007, 08:06 AM
Matts02
2015 WK
It is a really easy procedure--I just did mine last week. There is a drain bolt on the bottom and a fill plug on the side. Remove the fill plug before removing the drain plug, then drain the fluid into a pan. Once it is drained replace the plug and use a bottle pump to pump new RP synchromax in until it begins to run out the fill hole. That it is it. Now, the plugs take a 17mm allen wrench, which is very hard to find. What I did was take a 17mm socket to the hardware store and find a bolt that had a 17mm head. Then I tightened two nuts on each other at the end and simply stuck the head of the bolt into the plug and put a socket on the two nuts. This cost me about a buck--far cheaper than the cost of the 17mm allen wrench or bit.
Matts02 is offline
post #4 of 9 Old 09-06-2007, 08:26 AM
Zoom By You
Zoom By You's Avatar
http://www.4x4xplor.com/trannyservice.html
This is what you need....
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline
post #5 of 9 Old 09-06-2007, 10:36 AM
SecondTJ
SecondTJ's Avatar
Sears carries it.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #6 of 9 Old 09-06-2007, 11:12 AM
Crashnburn80
Crashnburn80's Avatar
Originally Posted by SecondTJ
Sears carries it.
x2, thats where I bought mine (and about every other tool).
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #7 of 9 Old 09-06-2007, 01:00 PM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
Originally Posted by Zoom By You
Thanks! That really helps with pictures and all.
Thanks for all the help guys, i should get the change done this weekend. I'm pretty sure i have the 17mm allen wrench, but I will check my tools. So the only other special tool i'll need is a bottle pump then?
Cheers,
Kelvyn
_______
|_
_|
(OlllllllO)
Panici is offline
post #8 of 9 Old 09-06-2007, 03:12 PM
Crashnburn80
Correct. FYI - FSM specifies 2qts, but its really more like 2.3-2.5 to the fill hole.
| 1.25" BL |
and much more...
post #9 of 9 Old 09-06-2007, 07:10 PM Thread Starter
Panici
(O|||||||O)
Panici's Avatar
Yep, when i ordered, i checked with my fellow jeepforum'ers and i was told 3 quarts for the NV3550. I ordered 4 quarts, because the last thing i would need is for a bottle to fall over and then i'd have to pay the CRAZY border charges again for "importing hazerdous materials"
_______
|_
_|
(OlllllllO)
Panici is offline
fluid for nv3550 Conti31 TJ Wrangler Technical Forum 22 08-31-2010 08:21 PM
Changing Transmision. What are the differences between the ax15 and nv3550? Arron TJ Wrangler Technical Forum 4 09-21-2009 09:33 AM
changing tranny fluid NV3550 03rubiconMG TJ Wrangler Technical Forum 2 05-31-2009 08:54 PM
YJ Transmission Fluid (MT90?) ,,,, metal piece when changing fluid GMC7000 YJ Wrangler Technical Forum 12 11-04-2008 07:11 PM
Changing trans fluid in NV3550 w/ Warn Skid plate Dollarbill TJ Wrangler Technical Forum 3 09-13-2007 12:36 PM
