#1 | |
Changing Manual Trans Fluid
Ok... so how many of you remove the TC skid Plate before changing the fluids??? OR do you leave it on??
____ (OlllllO) 65th Anniversary Edition TJ Jeep Green Rough Country 3.25" Suspension Lift JKS 1.25" Body Lift & 1" Budget Motor Mount Lift 33x12.50/15 BFG All-Terrain's on 15x8 ProComp Series 51 w/ 3.75" BS
#2 |
I leave mine on but... be prepared for a mess if you screw up directing the flow of the old fluid out of the transmission into your catch basin/bucket.
2012 JKU Rubi,Auto, 4.10's, All black including hardtop and fenders. : P 99 Sahara D30/44 w ARB's and 4.10's, Warn 9.5TI,AA SYE & Wood's shaft,Raingler nets,Jeeperman trail skids,Warn gas tank and steering box skid's, BDS 2" springs, Currie control arms,32" MTR's,AEV Bridger wheels, custom made tire carrier bumper,Dynomax cat back JKS quicker disco's.PSC Trail Cage,Banks header,LiteDots.PSC Trail Corners. 92 CDN M101 trailer, 33" TSL Swampers,camo paint. Original camo tarp. |
#3 |
yeah...thats what Im worried about.
#4 |
Left mine on, just be careful.
#5 |
I duct taped a piece of cardboard in the shape of a piece of paper folded in half length wise under it. As long as it's stable the gear oil will just roll down the cardboard into the drop pan. Toss the cardboard when you're down, no mess!
'98 TJ Emerald Pearl Coat |
#6 |
Tranny isn't really a problem since the drain plug is on the bottom. For the TC, I made a trough out of a thin piece of aluminum and channeled the oil to the big drain hole in the skid plate, of course with the catch pan under the skid. If you slowly remove the drain plug, you can regulate the flow coming out of the TC and have very little mess. Hope this helps.... oh and I used an empty round gear oil bottle with the tappered lid, slid a piece of clear 3/8" I.D. hose over it to fill things back up.
Flame Red 2005 Rubicon Unlimited, 4.0L, 6sp, dual tops, Valvoline VR-1 10w30 engine oil/M0-090 Mopar filter, Amsoil Synchromesh 5W30 trans. oil, IPF 920hc head light conversion with PIAA Xtreme White plus bulbs, PIAA Xtreme White Plus H-3 fogs, Armadillo front/rear bumper caps and Olympic grille guard. Amsoil SevereGear 75W140. |
#7 |
Good ideas guys!
Thanks!!
#8 |
i take mine off,
while the TC and Tranny are draining i pressure wash the skid, and shoot some fresh paint on it. i also touch up the frame where the skid mounts.... and apply a liberal coating of anti-seize to the skid mounting bolts before reinstalling the skid. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
