Changing Fuel Pump Assembly Soon - Best Brand/How To's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Changing Fuel Pump Assembly Soon - Best Brand/How To's?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-01-2012, 04:59 PM   #1
catnip15
2002 4.0L TJ
Going to be changing my Fuel Pump Assembly soon, was wondering what brand people have had luck with. I work at a parts store and can get an Airtex Fuel Pump Module Assembly for cheaper than anywhere else due to discount but its not necessarily the price Im concerned about, I just want something good that will work, and last me a long time.
Also I have never done this job before but I am assuming it is not that difficult, anything I should be aware of and extra tools I might need? Thanks
catnip15 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2012, 07:28 PM   #2
mukluk
I'm pretty happy with the original Mopar pump that was installed in my Jeep at the factory over thirteen years ago.
mukluk is online now   Reply With Quote Quick reply to this message
Unread 12-01-2012, 07:34 PM   #3
wushaw
Rockin jeep
wushaw's Avatar
I went with the Airtex, it has 6k miles on it so far and still works good.
wushaw is offline   Reply With Quote Quick reply to this message
Unread 12-01-2012, 07:40 PM   #4
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Bosch, genuine Jeep, or Carter. You buy cheap, you buy twice. Airtex often fail after about 18 months.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 12-01-2012, 07:51 PM   #5
Rio_Grande
I use mopar, the process of changing the pum isint bad. Try to run it low on fuel to save your back. Start spraying the bolts a few days out.
I love this crap!!
Rio_Grande is offline   Reply With Quote Quick reply to this message
Unread 12-01-2012, 09:00 PM   #6
Zakman
A locked & armored Sport
Zakman's Avatar
Just replaced mine about 2 weeks ago and went with a Mopar unit. The original one lasted 11 years, so that's hard to beat.
While you have the tank down, inspect, even replace all the evap lines and fuel filler & filler vent tubes while you're at it.
The only issue I had is getting the fuel filler and filler vent tubes up and squeezed in-between the the frame and tub.
Good luck.
_______
|_Jeep_|
(OlllllllO)
My Build Thread:
http://www.jeepforum.com/forum/f22/z...-sport-671095/
Zakman is offline   Reply With Quote Quick reply to this message
Unread 12-01-2012, 11:38 PM   #7
5-90
1988 XJ Cherokee
Use a brass mallet and a brass drift (heavy rod - about 3/8"-1/2" dia.) to unlock and relock the lock ring that retains the pump assembly!
You do not want sparks around there...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 03:31 AM   #8
Jonny Jeep
Jonny Jeep's Avatar
A good write up with loads of pics can be found on the http://dailydriventj.com/fuel_pump.shtml website with the title fuel pump repair.
Online factory service manuals and parts lists - http://www.jeep4x4center.com/knowledge-base/index.htm
If it doesn't work properly, look for the service manual link at the bottom of the page.
Last edited by Jonny Jeep; 12-02-2012 at 03:00 PM.. Reason: Changed link to go direct to the page now that I'm back on my computer.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 07:11 AM   #9
UnsanePyro
This.
Airtex I wouldn't touch.
SPI is hit or miss.
Carter/Bosch/OEM all seem to work really well.
UnsanePyro is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 07:29 AM   #10
gmiller0737
I went the Airtex Route Results not good Hard start issues that I didn't have before lived with that, At 8 months old pump failed with out warning & left Me in the middle of a busy 4 lane highway,Replaced with a Bosch from Carquest & the Bosch pump had a Mopar Part tag on it,So far it has been great no more hard start.
gmiller0737 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 11:55 AM   #11
brianmlove
Be sure to pull your fuel pump relay under the hood and try to start it a few time so you will
Clear all the fuel that is in the lines. If not expect to get a bath with gas when you remove the fuel line from the tank
brianmlove is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 11:58 AM   #12
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
A strap wrench works well on the lock ring.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 12-02-2012, 09:32 PM   #13
catnip15
Thanks for this awesome write-up, I will make sure to use this when im replaceing the pump saturday
Unread 12-02-2012, 09:34 PM   #14
catnip15
And I ended up purchasing a Carter from RockAuto for $218 plus shipped
