Changing Fuel Pump Assembly Soon - Best Brand/How To's? - JeepForum.com
post #1 of 14 Old 12-01-2012, 03:59 PM Thread Starter
catnip15
2002 4.0L TJ
Going to be changing my Fuel Pump Assembly soon, was wondering what brand people have had luck with. I work at a parts store and can get an Airtex Fuel Pump Module Assembly for cheaper than anywhere else due to discount but its not necessarily the price Im concerned about, I just want something good that will work, and last me a long time.
Also I have never done this job before but I am assuming it is not that difficult, anything I should be aware of and extra tools I might need? Thanks
catnip15 is offline
post #2 of 14 Old 12-01-2012, 06:28 PM
mukluk
I'm pretty happy with the original Mopar pump that was installed in my Jeep at the factory over thirteen years ago.
mukluk is offline
post #3 of 14 Old 12-01-2012, 06:34 PM
wushaw
Rockin jeep
wushaw's Avatar
I went with the Airtex, it has 6k miles on it so far and still works good.
wushaw is offline
post #4 of 14 Old 12-01-2012, 06:40 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Bosch, or genuine Jeep. You buy cheap, you buy twice. Airtex often fail after about 18 months.
CJ7-Tim is offline
post #5 of 14 Old 12-01-2012, 06:51 PM
Rio_Grande
I use mopar, the process of changing the pum isint bad. Try to run it low on fuel to save your back. Start spraying the bolts a few days out.
I love this crap!!
Rio_Grande is offline
post #6 of 14 Old 12-01-2012, 08:00 PM
Zakman
A locked & armored LJ
Zakman's Avatar
Just replaced mine about 2 weeks ago and went with a Mopar unit. The original one lasted 11 years, so that's hard to beat.
While you have the tank down, inspect, even replace all the evap lines and fuel filler & filler vent tubes while you're at it.
The only issue I had is getting the fuel filler and filler vent tubes up and squeezed in-between the the frame and tub.
Good luck.
My Build Threads:
2005 LJ - "Squad 51"
2002 TJ - "Minion" - RIP - 06/02/16 @ JJUSA - Badlands
Zakman is offline
post #7 of 14 Old 12-01-2012, 10:38 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Use a brass mallet and a brass drift (heavy rod - about 3/8"-1/2" dia.) to unlock and relock the lock ring that retains the pump assembly!
You do not want sparks around there...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #8 of 14 Old 12-02-2012, 02:31 AM
Jonny Jeep
Jonny Jeep's Avatar
A good write up with loads of pics can be found on the http://dailydriventj.com/fuel_pump.shtml website with the title fuel pump repair.
Last edited by Jonny Jeep; 12-02-2012 at 02:00 PM. Reason: Changed link to go direct to the page now that I'm back on my computer.
Jonny Jeep is offline
post #9 of 14 Old 12-02-2012, 06:11 AM
UnsanePyro
Originally Posted by CJ7-Tim View Post
Bosch, genuine Jeep, or Carter. You buy cheap, you buy twice. Airtex often fail after about 18 months.
This.
Airtex I wouldn't touch.
SPI is hit or miss.
Carter/Bosch/OEM all seem to work really well.
UnsanePyro is offline
post #10 of 14 Old 12-02-2012, 06:29 AM
gmiller0737
I went the Airtex Route Results not good Hard start issues that I didn't have before lived with that, At 8 months old pump failed with out warning & left Me in the middle of a busy 4 lane highway,Replaced with a Bosch from Carquest & the Bosch pump had a Mopar Part tag on it,So far it has been great no more hard start.
gmiller0737 is offline
post #11 of 14 Old 12-02-2012, 10:55 AM
brianmlove
Be sure to pull your fuel pump relay under the hood and try to start it a few time so you will
Clear all the fuel that is in the lines. If not expect to get a bath with gas when you remove the fuel line from the tank
brianmlove is offline
post #12 of 14 Old 12-02-2012, 10:58 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
A strap wrench works well on the lock ring.
Wheelin98TJ is offline
post #13 of 14 Old 12-02-2012, 08:32 PM Thread Starter
catnip15
Thanks for this awesome write-up, I will make sure to use this when im replaceing the pump saturday
catnip15 is offline
post #14 of 14 Old 12-02-2012, 08:34 PM Thread Starter
catnip15
And I ended up purchasing a Carter from RockAuto for $218 plus shipped
catnip15 is offline
