Changing Differential Oil - JeepForum.com
post #1 of 16 Old 03-18-2005, 08:03 AM Thread Starter
JEEPREBEL
I was wondering if it was possible to change the gear oil in the front and rear diffs with out taking the covers off. Could i use a suction device made for grese and pump it out? Or is it better to take the covers off and do it that way?
Thanks Chris
Red, 02 X, tan soft top, halfdoors, 3" BDS suspension lift, .75" Coil spacers up front. 33" BFG A/Ts
JEEPREBEL is offline
post #2 of 16 Old 03-18-2005, 08:12 AM
wayoflife
while it can be done and for whatever it's worht, that's how most oil change places do it, i wouldn't recommend it. pulling your diff covers give you a chance to inspect your gears and to make sure everything looks good. it will certianly allow for a more throuogh cleaning and it really isn't that hard to do.
Click here to see my Differential Fluid Change write-up
wayoflife is offline
post #3 of 16 Old 03-18-2005, 08:13 AM
BaaBaa
Take the covers off... there's no other way to be sure you've gotten all the fluid out for one. Also, you'll want to check the gears for wear, look at the inside of the housing for any metal shavings, and clean out the inside of the cover and diff. No point in putting fresh lube in there if you leave all the crud and a bit of old dirty lube in there as well.
Black 2000 TJ Sport
Black Jeep Club Version 2.0 Member #66
BaaBaa is offline
post #4 of 16 Old 03-18-2005, 08:27 AM
linux24
Thanks Chris
Is it possible? Given enough time, money, and energy, anything is possible.
I wouldn't do it. Part of changing that fluid is spraying brake cleaner up in there to remove grime and grit from inside the gears, and wiping crud from inside the assembly as much as possible and the inside of the cover. It also is a chance to perform an inspection to see if you see filings in there.
linux24
Jeep newbies and novice mechanics go here:
linux24 is offline
post #5 of 16 Old 03-18-2005, 09:06 AM
FlyersFan2009
FlyersFan2009's Avatar
I concur with the above posts.
Take the covers off and follow WayofLife's write up.
You should inspect the gears and check for metal in the bottom of the pumpkin.
FlyersFan2009 is offline
post #6 of 16 Old 03-18-2005, 11:27 AM
BluesMan
BluesMan's Avatar
Yup what they said.
It would be wize to read the write ups or FSM before you do this, if you have not done it before.
The project is one of the simplest to do.
I did this a couple of weeks ago and forgot to leave a couple of bolts connected at the top. Then went to take the cover off and it fell into the diff fluid below sending the stinking crap all over me and my garage.
...Don't follow Chili Palmer into the trees...
BluesMan is offline
post #7 of 16 Old 03-18-2005, 03:47 PM Thread Starter
JEEPREBEL
Honestly this was one of the easiest things Ive ever done to my jeep other than changin engine oil. Thanks Wayoflife the write up was really helpful.
Thanks, Chris
post #8 of 16 Old 03-18-2005, 04:09 PM
Ludoc
Ludoc's Avatar
Dude... This is the WORST part of servicing my TJ. I hate taking the covers off. However, after much debate and listening to the peeps around here, I have just come to live with removing the covers. It seems like the best option. Do a search with my name and look for a thread about some diff covers I was going to buy with a drain plug in them. EVERYONE basically told me to just live with it. I tend to listen to experience. I tried the suck gun method. It... well, sucks. Take the covers off. Basically get it in your head. Prepare for it if you hate it like I do.
Ok... I am done ranting.
RED 04' TJ - 2.4 4 In Lift, 31" Courser M/Ts, 4.56 gears, JKS Discos, Aussie Auto Locker
Just a basic Jeep... nothing special.
Ludoc is offline
post #9 of 16 Old 03-18-2005, 04:42 PM
KaiserJeep
One little tiny feature that Jeep didn't even advertize about the Rubicon makes me very happy. The front and rear D44's have magnetic drain plugs to drain the lube.
At 6000 miles I did remove the diff covers and spent some time cleaning out as much of the black stuff as I could get (it's oxide from the surface treatment). Since then I just pull both magnetic plugs and providing there is no metal debris on the plugs, drain and refill with lube. It saves time and no worries about a leak.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #10 of 16 Old 03-18-2005, 08:00 PM Thread Starter
JEEPREBEL
It wasnt too bad...the worst part was puttin the oil in the front diff (dont have a pump). So yeah it sucked.
Chris
post #11 of 16 Old 03-18-2005, 08:30 PM
Chile99
Chile99's Avatar
Next time you do the front diff, stop at the hardware store and buy 3 foot of clear plastic 3/8 inch flexible plastic tubing, put squueze bottle of diff fluid into one end of the tubing and the other end into the opening of the diff cover...........squeze.
99TJ 4.0 Auto, Lifted and Locked with a lot of Junk
94 yj 4.6 Stroker, 14Bolt, HP44, 101 wheelbase
I brake for Junk Yards
Chile99 is offline
post #12 of 16 Old 03-18-2005, 08:45 PM
BlueJ
SO what weight oil did you use and did you need the friction additive?
1998 XJ Up Country - "The Green Chili"
BlueJ is offline
post #13 of 16 Old 03-18-2005, 08:52 PM
Stu Olson
Stu Olson's Avatar
FSM call for 80W-90 or 75W-140 synthetic (the heavier if you tow or subject the axle to heavy use).
Friction modifer is used if you have a clutch pack LSD like the factory LSD option. Most gear lubes come with the friction modifier in them. Check the label to be sure.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #14 of 16 Old 03-18-2005, 09:24 PM
BlueJ
And what like 3 quarts I suppose?
Hey Stu, what brand is a good synthetic?
BlueJ is offline
post #15 of 16 Old 03-18-2005, 09:51 PM
Stu Olson
Stu Olson's Avatar
I use Mobil1 myself. Redline makes a good synthetic gear lube.
http://www.stu-offroad.com/misc/maint.htm gives you quantities for fluids among lots of other common maintenance info.
Stu Olson
ARB Locked & Loaded
changing differential and T-case oil mike68 TJ Wrangler Technical Forum 12 11-21-2007 06:41 PM
changing differential fluid? to do or not to do? vargeg60 TJ Wrangler Technical Forum 18 12-30-2006 10:36 AM
when changing the differential fluid.. losfreddy TJ Wrangler Technical Forum 9 06-17-2006 09:07 PM
Changing differential fluid sinkisbusted TJ Wrangler Technical Forum 4 07-28-2005 09:21 PM
Changing Differential Fluids OffRoad98 TJ Wrangler Technical Forum 15 07-12-2005 10:22 PM
