Changing AX-5 fluid - JeepForum.com
post #1 of 2 Old 11-02-2007, 01:26 PM Thread Starter
newcaddy4j
newcaddy4j's Avatar
Changing AX-5 fluid
Hey,
I'm planning on changing the fluid in my 2000 se to Redline MTL. I looked at it the other day and am assuming the drain plug and the fill plug are the same sized bolt (5/8?). Is this correct?
Jeepless....
Keep it Real Ol' XJ and TJ
"Many men go fishing all of their lives without knowing that it is not fish they are after."
newcaddy4j is offline
post #2 of 2 Old 11-02-2007, 01:55 PM
Jeepdawgs
Pull fuse #4 !!!!!!!
Jeepdawgs's Avatar
Originally Posted by newcaddy4j
Hey,
If I remember right they are the same size bolt. Also a word of advice. Loosen/Remove the fill plug first and then the drain plug. Hate to see you drain the fluid and then realize you can't get the fill plug out.
'99 Gun Metal Blue TJ
5 spd Manual
31x10.50 BFG KO's
2" Tereflex lift, Rancho Steering Stablizer
Mauser K98 (1941),K31(early 50's), Mosin-Nagant M44 (1946), BUL Impact .45, Ruger Mark2, CZ-50, Marlin .22, Winchester.22
Low Output 4-Cylinder Jeep Club #50
"Dyslexia for cure found"
Jeepdawgs is offline
Changing clutch fluid and what fluid to use. RedDawn TJ Wrangler Technical Forum 4 05-08-2009 01:34 PM
Changing fluid on a AX5 MikeyJ YJ Wrangler Technical Forum 21 03-04-2009 06:27 PM
YJ Transmission Fluid (MT90?) ,,,, metal piece when changing fluid GMC7000 YJ Wrangler Technical Forum 12 11-04-2008 07:11 PM
Changing fluid in BA 10/5 thisfatguy YJ Wrangler Technical Forum 4 07-30-2006 12:12 PM
Changing diff fluid Skully TJ Wrangler Technical Forum 10 03-23-2004 07:50 PM
