Quantcast Changing Auto trans fluid??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Changing Auto trans fluid???
Old 04-11-2007, 09:05 AM   #1
bluejeepjeep
How often does the automatic transmission fluid need to be changed in a 2004 Unlimited?
Does it just need changed or the whole flush??
bluejeepjeep is offline   Reply With Quote
Old 04-11-2007, 10:12 AM   #2
dz1087
Can't remember when it needs changing, but after talking to a lot of tranny mechanics, I get the feeling that the whole flushing thing is a waste of money. They have told me that the best thing you can do is to have a tranny shop change the fluid/filter and have them check all the torque and condition of the components inside. When you get it flushed, they don't check anything, so if you have something comming loose in there, it won't get any attention.
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
http://www.jeepforum.com/forum/f176/list-state-mirror-laws-565361/
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline   Reply With Quote
Old 04-11-2007, 10:23 AM   #3
SYN ACK
I'm not sure but I had Jeep do mine. It wasn't that expensive either.
SYN ACK is offline   Reply With Quote
Old 04-11-2007, 06:36 PM   #4
PhulesAu
The dealer doesn't recomend any thing more than the flush.
04 L J
Travel'n Gadget Show
KE5PPH
PhulesAu is offline   Reply With Quote
Old 04-11-2007, 06:46 PM   #5
redvett94
Look in your owners manual under maintance.
2000 Sport.
redvett94 is offline   Reply With Quote
Old 04-11-2007, 07:28 PM   #6
otisdog
It's at 30K in the owner manual. I changed mine at 30. Just drained it and put in a new filter and refilled. Took 5quarts to refill.
Probably will do mine every 10 - 20K now.
There are no bands on the 42RLE so no adjustments needed.
Jim
03 Sport
otisdog is offline   Reply With Quote
Old 04-11-2007, 07:31 PM   #7
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
I'm going to say somewhere in the 60-70k range.
I have heard that if you've gotten to the 110k range without any problems then you shouldn't get the flush. Sometimes the sediment/crap settles in a good spot where it cant get disturbed. Then if it's flushed the sediment/crap might settle in a valve.
I did a fluid/filter change @ 60k and the fluid wasn't too bad. And that's with the 32" 3.07 combo. So I know my trans is working to get my heep moving when I floor it.
Edit:
Manual says 37,500 (for normal operation) & 24k (for agressive stop&go driving).
Drain & Fill, Change Filter, Adjust Bands
30k for the transfercase in both situations.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline   Reply With Quote
Old 04-12-2007, 06:36 AM   #8
bluejeepjeep
So I looked in the manual last night and it said that the fluid in it should last the lifetime of the vehicle unless water gets in it.
Did they mean that for a manual?? Does that sound right.
I understand I need to have the filter changed, should the fluid be changed when that happens?
Glock Forum
