Champion 3 row aluminum radiator (review) - Page 6 - JeepForum.com
post #76 of 277 Old 02-09-2010, 06:23 PM
Robert J. yates
Been there done that on the copper Radiator Barn special. It didn't work worth a crap and ended up cracking at the bottom tank so advising folks to go with a $175 copper replacement is in my experience, not very good.
As for aluminum radiators having durability issues.... aluminum radiators are stock from the factory which means they were subjected to Jeeps' durability testing. Yes they can leak at the tank but then that can be repaired by anybody with a pair of channel locks and a gasket. My Novak aluminum radiator has been in my Jeep over 3 years now with NO problems. Its fits, its clean and frankly, unless I roll my Jeep and crush it or push the fan into it, I seriously doubt that it is going to cause me anymore problems than the STOCK ALUMINUM radiator did. (caps for emphasis) There are more than a few trail fixes for leaking radiators which do not care what the metal involved is.
Robert J. yates is offline
post #77 of 277 Old 02-09-2010, 06:32 PM
mightydog78
gosh why does everyone like electric fans? ive heard more bad things about them and the pain the are to install than i have leaving the stock belt fan in...
does it really matter that getting an all aluminum radiator you should also get an electric fan
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #78 of 277 Old 02-09-2010, 07:04 PM
purplepig
I did try crimping them back together and I think it helped a little bit. Is it really possible to change the gasket?
purplepig is offline
post #79 of 277 Old 02-09-2010, 07:06 PM
purplepig
thanks, Billymac
post #80 of 277 Old 02-09-2010, 07:06 PM
TJdualsport
the best temp fix is a raw egg dumped into the radiator saw it on mythbusters. it worked lol
in regards to durability, off road and on road motorsports have been using aluminum radiators for years.
As far as cost. Champion is selling a fully tigged Aluminum radiator, 3 row construction, rated to almost 800hp for $200.00 other advantages of the aluminum is the tube sizes and amount of fins that can be utilized over the Copper/brass
TJdualsport is offline
post #81 of 277 Old 02-09-2010, 07:22 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by ohiobeach View Post
what was wrong with your radiator? I bought one last year and I will get this Mcchampion if Radiator Barn is crap.
Yep...
Knuckelhead is offline
post #82 of 277 Old 02-09-2010, 09:28 PM
billymac4511
This is another one of the flaws with a plastic/aluminum radiator. Many folks think you can 'easily' change the tanks/gaskets whatever with just a screwdriver and some chanel locks. Ever bend an aluminum tab on something and then bend it back? Yeah, 90% of the time it snaps off. While some folks will tell you that you can 'easily repair' a PAL radiator or replace it's tanks, they're in it for your money or haven't worked with rads that much.
Yes, there is a crimp tool that's specifically designed to un-crimp the tabs on a PAL radiator so you can theoretically remove the tank and gasket and TOC/EOC. Yes, the tool does a great job un-crimping the tabs. The issue is when you replace the tank and gasket and cooler, re-crimping the tabs which are attached to the headplate and core, they either snap off completely or don't hold worth a damn. You leak anyway. =/
Webmaster and official do-gooder of interwebbish thinggies at
Also guilty for the plague, broken egg yolks and the spork.
billymac4511 is offline
post #83 of 277 Old 02-09-2010, 09:43 PM
billymac4511
The only rebuttal I have for your comment is, if you buy cheapo-depot specials, you'll probably get cheapo-depot special performance out of them...
Buy a quality part and you'll most likely get quality performance out of that part.
You're absolutely right. Plastic/Aluminum radiators are great! They obviously are or just about every single auto manufacturer on the planet wouldn't be using them! You're also right that unless you do something pretty aggressive to your rig, that radiator will probably be 100% fine for your application.
My comments suggesting an upgrade to a copper/brass radiator instead of an "ALL aluminum" (keep in mind, all alum and PAL are two COMPLETELY different beasts) were based upon the person's interest in an all aluminum upgrade. If they were intending on showing their rig or basically wanting/needing the extra "Bling" under the hood, then an all aluminum with billet cap and diamond-studded mounting bolts are definitely the way to go!
But, for half the price, a do-it-yourself'er could upgrade the durability of their stock rad by replacing it with a repairable CBR part. The stock PAL rads are not something that should be repaired and expected to offer continued reliable service.
post #84 of 277 Old 02-10-2010, 07:53 AM
purplepig
Not a good idea, unless you want to cause other problems down the road.
After reading everyones comments, I have decided to go with the factory style. It lasted for 90K miles, so hopefully I will get that out of a new one. By the way, it is still cooling great, just a leak at the crimp that I have been watching for months now. Maybe I can find one with a lifetime warranty. Where is a good place to buy one? It seems that Radiator Barn and Radiator Express are out.
post #85 of 277 Old 02-10-2010, 08:36 AM
mightydog78
yeah the only reason im replacing my stocker is there is brown liquid all in the radiator
it shouldnt be oil because my oil level/pressure is steady.
2013 JKU Sahara
Mechanical Engineer
post #86 of 277 Old 02-10-2010, 09:17 AM
billymac4511
When was the last time you flushed/filled it?
Is it the factory antifreeze? You know, the orange specialty stuff(OATS or dex-cool or whatever ... no, I know they're not the same) or is it normal green classic antifreeze that has the brown goo in it?
post #87 of 277 Old 02-10-2010, 10:00 AM
Tjosh97
I think I'm about due for a new radiator just got a leak in my CSF All-metal . Still debating wether to got with a CSF Aluminum radiator or a Champion Aluminum. I just dont like all that Chrome on the Champions. But looks and sounds like a good radiator.
CSF Inc. - Illustration And Specifications
Beep Beep, who got da keys to the JEEP???
Red Jeep Club #556 - "DA 4-$LANGER"
1997 Flame Red TJ 4-Banger (2.5L) 4.0 TB 62mm Bored w/ Spacer -- 31x10.50 D. Cepek "Crushers" -- 15" Black Rock Crawlers -- AEM DryFlow -- Dynomax Super Turbo Cat-Back -- EBC Brake System -- Rough Country 2.5" Lift w/ Discos -- RC Adj Track Bars -- Currie HD Steering -- Rugged Ridge Diff Covers - DDM 6000K HID
Tjosh97 is offline
post #88 of 277 Old 02-10-2010, 10:20 AM
Tjosh97
Its Zerex not Dex-Cool
Tjosh97 is offline
post #89 of 277 Old 02-10-2010, 11:30 AM
mightydog78
i flushed it about 4 months ago when my antifreeze plug blew off on the highway. the truck behind me got a nice bath of coolant
i think it's brown because my radiator is corroding, or maybe because my heater barely puts out any heat
2013 JKU Sahara
Mechanical Engineer
post #90 of 277 Old 02-10-2010, 12:05 PM
Robert J. yates
See...thats the issue I'm having with your comments. You sound as if you are informed and then you post up a bunch of drivel that somehow, aluminum radiators are only for show. That is hardly the case so I'll put it to you another way. Tell me...why are most desert trucks, sand cars and rock buggies fitted with aluminum coolers? I surely don't think competition at that level has anything to do with bling or diamond studded mounting bolts
You live in Maine so your needs are probably different than mine due to the fact that I live and wheel primarily in the desert where seeing 100* plus temepratures is a very common occurance. I'll let you in on another secret too... my radiator is not the only cooler on my truck.... there are 3 more aftermarket coolers that I have added to my rig. Care to guess what they are?
aluminum , install , jeep , radiator , review , tj
Champion 3 row aluminum radiator for 250 shipped? MO1535M TJ Wrangler Technical Forum 24 04-02-2013 07:05 AM
New Radiator - Silla All Aluminum Border Dave TJ Wrangler Technical Forum 35 03-11-2010 02:25 PM
Aluminum vs 3 core radiator 69junk YJ Wrangler Technical Forum 23 09-03-2009 07:49 PM
Who is running an all Aluminum Radiator Canfourjeep YJ Wrangler Technical Forum 19 06-06-2008 12:57 PM
Inexensive Aluminum Radiator?! TJ Hooker TJ Wrangler Technical Forum 9 03-03-2008 08:57 PM
