Champion 3 row aluminum radiator (review) - Page 2 - JeepForum.com
post #16 of 277 Old 01-29-2010, 07:06 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
Originally Posted by Knuckelhead View Post
What was the cost of the radiator?....
They're on eBay for $200...
87 88 89 90 91-06 Jeep Wrangler 3 Row Champion Radiator : eBay Motors (item 110483914016 end time Jan-29-10 19:19:22 PST)
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #17 of 277 Old 01-29-2010, 11:41 PM
tshively
I just installed one of these. The radiator cost $199+$20? freight. I went ahead and used the flex-lite electric fan that the previous owner installed. It is a very tight fit. I have played with the flex-lite electric fan and the factory mechanical fan and IMO the factory (mechanical) fan moves way more air. We will see how it goes I am quite sure the mechanical fan will be going on for good.
tshively is offline
post #18 of 277 Old 01-29-2010, 11:59 PM Thread Starter
sergeantspud
I paid $220 for the radiator, $20 for the fan, and $35 FedEx shipping.
Nice, where's the shroud? Not many know how incredibly important the shroud is to proper cooling since it forces air through the radiator and prevents the air from just spilling off the tips of the fan blades. Poor cooling/hotter running engines are often nothing more than a damaged/torn shroud, let alone one that isn't even there.
Hmm, I'm sure if I starting thinking about it for a few days I'll come up with some way to make a shroud with some sheet metal and a few correctly placed bends, cuts, and bolts.
As of right now though, 70 degree weather the temp is just fine siting still around 10-15 bellow normal temp of 210 (still estimating with stock gauge) and the fan has not turned on once unless I idle it for 5 min then it turns on for a minute or two and off again for another 5.
sergeantspud is offline
post #19 of 277 Old 01-30-2010, 06:57 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Knuckelhead is offline
post #20 of 277 Old 01-31-2010, 01:40 AM
bmxrules39
Originally Posted by Bubba3200 View Post
I have a flex-a-lite and any mph over 30 mph it shuts off. If you have to run your electric fan @ hwy speeds even in the summer you might have an issue somewhere in the cooling system. In the summer and on the freeway and with A/C on the fan might stay on a mile or so after I approach hwy speeds. I dont know what a Tarus fan pulls cfm wise but mine is 3300 and I never have any problem. I also tow a 1500 load sometimes and it is fine. Somekind of shroud is very important for air flow at slow speeds.
I guess it's possible I have a problem in my cooling system, but it made sense to me that since my engine is working harder at a constant rate, and pushing so much air with that flat grill and windshield, that it would start to warm up. But I'm no air flow scientist, that just made sense to me.
BTW did you have an aluminum radiator?
¤wHitt¤
bmxrules39 is offline
post #21 of 277 Old 01-31-2010, 09:38 PM
Bubba3200
No I have a 3 core all metal radiator barn one going strong for 3 years now. I am just commenting on how my set-up works. No scientist here. I just looked at a Tarus fan, 2 small fans I believe and it seems to me that the 17 inch single fan I have covers more of the rediator than two of the smaller fans. The flex-a-lite comes mounted in a shroud so to speak. It just seems that at hwy speeds you just dont need a fan with all the air coming through. I always keep an eye on my A/C condensor in front or the radiator....that it dosent get too bent up restricting the air flow to the radiator. With this cold weather we have been having I can run around all day and the fan never kicks on till I park the jeep and then it runs a bit till the rad is cooled off.
Bubba3200 is offline
post #22 of 277 Old 02-02-2010, 04:19 AM Thread Starter
sergeantspud
Just finished a complete tank of gas and calculated out to 1mpg increase! From 14.3 to 15.2 mostly highway (55mph) but some city (I didn't sit in any traffic) oh and some mountain driving. More than I thought it would be. The electric fan hasn't come on yet unless I'm sitting in a drive through or just idling. Also, put in the other switch and LED status light. Will keep you update for when I sort out a way to make a shroud.
post #23 of 277 Old 02-02-2010, 09:00 AM
Greg_Volkman
This is ironic. I just bought one on the 1st after having a leaking Novak aluminum radiator for 3 years.
It's supposed to arrive tomorrow. It looks very high quality (better than the one I have now), and they seem to have pride in what they do. Got mine off of ebay - they have awesome feedback on there.
I installed a flex fan from Summit when I put my Novak in (it's over 3" wide), so I think that will work just fine with the radiator - it doesn't look as wide as the Novak.
I'm excited...I actually get to DRIVE my heep again. Imagine that.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #24 of 277 Old 02-02-2010, 09:07 AM
Greg_Volkman
Originally Posted by sergeantspud View Post
So after 150k miles my stock radiator started leaking and started the search for a new radiator. Now as a background I did have some problems over heating, but only with the worst of the worst situation like doing 3k rpm at 75mph in 105 degree heat with the A/C on. So I figure in order to counter that I'd like an upgraded radiator instead of the stock OEM replacement.
I've looked around on here for hours and have seen someone bought a Silla 2 row aluminum radiator and I liked it but the thing that sold me on the Champion one is that the fill neck is billet welded and not stamped in. Also I saw that it was mentioned on here that 3 row is bad... but I took the chance anyways.
After putting it in and replacing coolant, hoses, and thermostat (stock temp 195) I drove it around for a few hours down the freeway and all around town and the temp stuck around 10degrees cooler according to the stock temp gauge with mechanical fan. So far it seems to be working good.
Along with the radiator, I also got an electric fan and hooked that up yesterday it turns on at 200 and off at 180 and seems to work awesome hoping for better highway milage but I'll find out soon.
(last time I posted pics they were blocked to lower members I apologize for all the links)
http://i102.photobucket.com/albums/m...r/DSCN0507.jpg
The welds are actually pretty nice looking.
http://i102.photobucket.com/albums/m...r/DSCN0509.jpg
http://i102.photobucket.com/albums/m...r/DSCN0515.jpg
http://i102.photobucket.com/albums/m...r/DSCN0506.jpg
Picture of the mounts that I made, they fit quite well.
http://i102.photobucket.com/albums/m...r/DSCN0514.jpg
The mounted fan
http://i102.photobucket.com/albums/m...r/DSCN0518.jpg
Another of the mounted fan
http://i102.photobucket.com/albums/m...r/DSCN0519.jpg
The switch that is a "manual off" I will be adding a "manual on" and a LED light to show when the fan is on or off.
And heres a link to an album with the rest of the pictures
Radiator pictures by sergeantspud - Photobucket
Sooo questions comments?
Can you do me a favor and measure from the fan pulley mounting surface to your radiator fins? I may need to get a shorter pulley spacer for me flex fan. Mine is a 1" spacer to fit my current novak radiator
-0|||||||0-
post #25 of 277 Old 02-02-2010, 09:11 AM
purplepig
I am on a search for a new radiator. I know I don't want the factory plastic/aluminum (that is the source of my leak now). What else do I need to look for? What is the advantage to the 3 row. If it makes the car run cooler than factory, wouldn't that cause other problems?
purplepig is offline
post #26 of 277 Old 02-02-2010, 06:30 PM
Greg_Volkman
This is where I got mine, it's $5 cheaper:
ALUMINUM 3 ROW RADIATOR 1987-06 JEEP WRANGLER CC2101 : eBay Motors (item 200387092139 end time Feb-19-10 23:36:51 PST)
-0|||||||0-
post #27 of 277 Old 02-03-2010, 08:47 PM
Greg_Volkman
Just a side note - I got mine today. I don't put crap on my jeep, and this radiator appears to be very high quality. the welds look very good, there is no epoxy (which is more than I can say for the Novak), and the radiator bolted right up. For those with stock fans, you might have to go with a flex fan or an electrical fan. I am very happy, and it was a full $200 less than the novak aluminum radiator I had in, and much higher quality. I am a happy camper.
-0|||||||0-
post #28 of 277 Old 02-03-2010, 08:50 PM Thread Starter
sergeantspud
Same here still running very strong with no leaks. Just wanted to add to Greg's post that I originally had my stock fan shroud and fan bolted up and it worked find with all stock mounts pre-threaded in the radiator.
post #29 of 277 Old 02-03-2010, 08:53 PM
SpaceWrangler
Gnarly Adventurer
Umm... how come?
post #30 of 277 Old 02-03-2010, 10:13 PM
mike_dippert
mike_dippert's Avatar
Originally Posted by Stretch67 View Post
Umm... how come?
I'm gonna venture to say it's thicker...
Greg, what's the thickness of that radiator?
mike_dippert is offline
aluminum , install , jeep , radiator , review , tj
Champion 3 row aluminum radiator for 250 shipped? MO1535M TJ Wrangler Technical Forum 24 04-02-2013 07:05 AM
New Radiator - Silla All Aluminum Border Dave TJ Wrangler Technical Forum 35 03-11-2010 02:25 PM
Aluminum vs 3 core radiator 69junk YJ Wrangler Technical Forum 23 09-03-2009 07:49 PM
Who is running an all Aluminum Radiator Canfourjeep YJ Wrangler Technical Forum 19 06-06-2008 12:57 PM
Inexensive Aluminum Radiator?! TJ Hooker TJ Wrangler Technical Forum 9 03-03-2008 08:57 PM
