Centering Rear Axle - JeepForum.com
post #1 of 5 Old 01-03-2014, 08:06 PM Thread Starter
OleBlue73
1973 CJ5
Centering Rear Axle
I'm in the process of installing my 2" BDS lift on my 2005. I started on and am currently working the rear axle. Springs are in and stabilizer bars are hooks up, but I can't seemed to push the axle far enough to the drivers side to line the lower control arms back up with the frame brackets. What's the trick?
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #2 of 5 Old 01-03-2014, 08:45 PM Thread Starter
OleBlue73
1973 CJ5
Doh! I just read the instructions again. Track bar should have been disconnected. I had my mind on control arms.
2009 JKU, Rubicon
post #3 of 5 Old 01-04-2014, 01:35 PM
durango-bob
2006 WK
Keep all the control arm bolts loose and use a ratchet strap to pull it into place. Once it is on the ground, then tighten all the bolts. If you tighten the bolts with the suspension drooped, you will preload the bushings and they will wear out quickly.
durango-bob is offline
post #4 of 5 Old 01-04-2014, 01:41 PM Thread Starter
OleBlue73
1973 CJ5
Once I disconnected the track bar, I was able to get things back together. While on the ground, I see the axle is more to the passenger side than centered. I guess it's due to the factory track bar length with 2" lift.
2009 JKU, Rubicon
post #5 of 5 Old 01-04-2014, 01:51 PM
Jeffro06
Jeffro06's Avatar
Track bar relocation bracket would fix that.
Jeffro06 is offline
