Centerforce ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Centerforce ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 03-12-2006, 05:44 PM   #1
al666
Centerforce ?
I dropped my tranny to look at my clutch due to no pedal feel. well i found out i blew 2 out of the 4 springs on the clutch plate. im going to buy a centerforce but dont know if i should get teh regular one or the dual friction one cause its only 40 bucks more. i have the 4cly with 33's and the clutch gets a good amount of beating. is the dual friction to hard for a daily driver? anyone running one or have a thought about it tell me what u think. thanks
al666 is offline   Reply With Quote
Unread 03-12-2006, 06:23 PM   #2
al666
anyone running these or no?
Unread 03-12-2006, 06:34 PM   #3
StealthTJ
LUK is really about the best that you can get.
Simply can't go wrong with the LUK.
The Centerforce "dual friction" really won't do anything helpful for you.
If you were spinning a zillion rpms, then maybe.
Look at either re-gearing and/or a 4:1 and give your clutch a break, plus you'll vastly improve your off roadability.
Fred
[b]Base[/b] - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
[b]Suspension[/b]- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
[b]Misc[/b] - Tera 2wd lo.
[b]Tires[/b] - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
[b]Recovery[/b] - Warn XD9000i
StealthTJ is offline   Reply With Quote
Unread 03-12-2006, 06:45 PM   #4
hoosier724
http://www.dialaclutch.com/dac-demo/search.asp
'03 TJ Sport,Light Tan Metallic,, Superlift 4" with BFG 33x12.5x15
Honk if you love Jesus...text while driving if you want to meet him!
hoosier724 is offline   Reply With Quote
Unread 03-13-2006, 12:09 AM   #5
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I would avoid a Centerforce clutch whose design is more for high HP/high RPM engines. It's real hard to beat the quality and longevity of the OE clutch (mine has 162K HARD miles on it) or Luk... who makes the OE clutch.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
