Center dash bezel removal, please help - JeepForum.com
post #1 of 7 Old 02-23-2007, 04:48 PM Thread Starter
eadgbe194
eadgbe194's Avatar
I am following this write up http://www.jeepforum.com/forum/f9/heater-core-walk-through-pictures-inside-211640/
I have removed the long skinny clip on piece, I can't figure out how to get the center dash bezel off, I don't have an ashtray in the dash that i can remove to get to the screw behind it. any help would be much appriciated.
Thanks
eadgbe194 is offline
post #2 of 7 Old 02-23-2007, 05:00 PM
Fox Fader
Two screws up top by the winsheild
One behind the ashtray (on mine)
Then it pulls off.
God Rules!
Fox Fader is offline
post #3 of 7 Old 02-23-2007, 05:04 PM
amiller
yeah, if you dont have an ashtray, just pull (once the top two screws are out. the clips that retain the bezel may stay in the dash, but they aren't too tough to remove and reinstall on the bezel
2005 Jeep TJ with some upgrades
amiller is offline
post #4 of 7 Old 02-23-2007, 07:26 PM
ribbitt617
Try not to pull too hard on the top. The littel tray will catch on the HVAC vents. Pull on the bottom to loosen it up first, then lift it up while pulling it out. I bent mine up a little by not paying attention.
"Roads? Where we're going... we don't need roads"
'06 Anniversary Edition, Black on Black
ribbitt617 is offline
post #5 of 7 Old 02-24-2007, 07:24 AM Thread Starter
eadgbe194
eadgbe194's Avatar
Thanks guys, I got it off. Just have to pull REALLY hard. The only screws were the 2 in the top. The clips did stay behind in the dash but i got them out with some needle nosed pliers. Putting it back on went much smoother.
post #6 of 7 Old 02-24-2007, 07:28 AM
ptowntj
ptowntj's Avatar
Just remember how easy that is to remove when you decide to leave your faceplate on for the night!
Really though, you were able to access the two screws that are up top, mine were buried underneath the dash piece, and in my frustrations and ended up breaking them off, but the alarm installer had already busted it up pretty good. I guess it must be only my jeep, but I don't see how one could get a screwdriver in that gap. Congrats
8 lug xj.
ptowntj is offline
post #7 of 7 Old 02-24-2007, 07:46 AM Thread Starter
eadgbe194
eadgbe194's Avatar
the top dash piece was only held on with 5 clips so I just used a flat tip screwdriver to pop it off, then it's just 2 screws that you can very easily get to on the top of the dash. But pulling the center bezel off without bending/breaking it was a huge pain. I have the factory radio so I'm not too worried about someone stealing it, it did come with sirius but you'd never know by looking at it, and if someone takes it then I get to buy a new head unit and a tuffy overhead console
Painted Center Bezel and Dash Cluster....not sure.. A1A-LJ Wrangler General Discussion 20 02-21-2009 06:32 AM
Removing center dash bezel? GOLENJEEPTJ TJ Wrangler Technical Forum 3 12-26-2008 06:26 PM
2006 TJ center dash bezel phonewiz TJ Wrangler Technical Forum 1 04-13-2008 06:30 PM
Need to find a center dash bezel somaj TJ Wrangler Technical Forum 4 12-08-2006 02:26 PM
Dash Switch Plastic Bezel Removal highcenter TJ Wrangler Technical Forum 3 03-23-2006 03:47 PM
