Center Console Speaker - JeepForum.com
post #1 of 15 Old 02-13-2013, 12:48 PM Thread Starter
hoytman62
Being new of owning my first Jeep TJ (2006), I have the center console out and see that you can put a speaker in it but I don't see any speaker wires to hook onto it. Has anyone ever put a speaker in and how do you wire it up? Maybe a video somewhere on it?
Thanks for any help!
hoytman62 is offline
post #2 of 15 Old 02-13-2013, 03:08 PM
tyvanwie
They came stock with a subwoofer. Someone took it and the wiring out.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #3 of 15 Old 02-13-2013, 05:01 PM
PC96
Not all TJ's came with the center console subwoofer
PC96 is offline
post #4 of 15 Old 02-13-2013, 05:09 PM
tyvanwie
Wasn't it just later models?
tyvanwie is offline
post #5 of 15 Old 02-13-2013, 05:12 PM
MinnesotaBill
My 06 LJ has one.
MinnesotaBill is offline
post #6 of 15 Old 02-13-2013, 05:12 PM
jamborick
I have a 2001 that came with a sub. I've since replaced it with a Kicker from Quadratec.
jamborick is offline
post #7 of 15 Old 02-13-2013, 05:27 PM
Davf24
sub woofer
Only some models came with the sub woofer option, I believe that all TJ's are wired for the subwoofer, the cable connector should be under the consul close to the E-break attached to the floor.
Davf24 is offline
post #8 of 15 Old 02-13-2013, 05:44 PM
2jhanna
The center console sub-woofer was an option, 7 speaker/subwoofer sound system.
If you had it to start with, the console's storage area was cut to approx 10% vs without the option.
jhanna
denton county, tx
2jhanna is offline
post #9 of 15 Old 02-13-2013, 07:02 PM
willatthe4077th
My 06 X came with a factory sub and was set up for a fleet vehicle so it had ZERO extras selected. If you have the spot for it, the wiring is probably there somewhere, unless someone took it out.
Check out this thread, I did this to mine and it's WAY better than stock. If you ever find the wiring that is.
http://www.jeepforum.com/forum/f20/h...woofer-579589/
willatthe4077th is offline
post #10 of 15 Old 02-13-2013, 08:34 PM
frenchy206
My 03 had a factory sub. If you're gonna put a sub there, do it right the first time. The factory sub was a dinky 6.5''. SSV Works makes a sub box that will fit perfectly in there and will hold a 10''. It's fairly easy to replace.
03 TJ Rubicon
frenchy206 is offline
post #11 of 15 Old 02-14-2013, 09:36 AM
Neil F.
Alright, some misinformation here:
- Jeep installed center consoles with speaker grilles without the factory sub option. The storage compartment goes all the way down
- The factory sub and wiring was part of the 7 speaker option package.
- The sub and amp is in an enclosure that takes up much of the console and there is only a shallow compartment
- You can't just mount a speaker in the non sub console. It is too flimsy and open.
- You can find factory sub enclosures but they go for a lot and there are better sound options out there
- There are plans in threads to build an enclosure to fit in the console o
- There are many small power subs on the market that are easy to install and put under a seat.
Neil F. is offline
post #12 of 15 Old 02-14-2013, 05:35 PM
frenchy206
Op, could you post a pic of your center console?
03 TJ Rubicon
post #13 of 15 Old 03-08-2013, 05:00 AM
ospreyfe55
2016 BU Renegade
Where the link to the thread you mentioned?
ospreyfe55 is offline
post #14 of 15 Old 03-08-2013, 09:30 AM
willatthe4077th
post #15 of 15 Old 03-08-2013, 04:24 PM
ospreyfe55
2016 BU Renegade
Thanks
