Center Console lock replace/Rebuild? - JeepForum.com
post #1 of 4 Old 07-29-2010, 10:03 AM Thread Starter
Lastshot
My center lock is in disrepair. The part that holds the latch is cracked, but the actual pins and tumbler are fully functional. is there anyway I can rebuild it so that I can still use my Ignition key, but fix the lock?
Any other options besides going tuffy?
{Project
-'05 LJ build }~{SOLD '98 TJ -
{You know you drive a TJ
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline
post #2 of 4 Old 07-29-2010, 12:18 PM
Jonny Jeep
Jonny Jeep's Avatar
I did the write up in post 8 of the linked thread to help out some in the past. If it's what I've called housing/latch you'd need to buy a new assembly from Jeep. You swap your lock cylinder into the new housing. The thread shows how to take out the cylinder without breaking it.
http://www.jeepforum.com/forum/f9/st...hanism-541962/
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #3 of 4 Old 07-30-2010, 09:32 AM Thread Starter
Lastshot
Thanks, Just what I needed Do you have a Part number for that? If not I'll just explain to the guy at the dealer what I'm doin.
{Project
gily25 Says...
Mike318 Says...
Lastshot is offline
post #4 of 4 Old 07-30-2010, 03:35 PM
Jonny Jeep
Jonny Jeep's Avatar
4741954 should be the part number for what I've called housing/latch and the retainer. The retainer was a different length on the one I bought so I just used the original one. I broke my lock cylinder and then worked out how to remove it, hence having to buy another cylinder too and doing the write up to save other people making the same mistake.
center console , replace , lock , repair , rebuild , tj , wrangler
Center console lock??? help!?! JWitt333 TJ Wrangler Technical Forum 11 12-18-2011 05:19 PM
Will '97 center console replace '05 console? green05TJ TJ Wrangler Technical Forum 4 03-28-2011 07:16 PM
Center Console Lock Help! CONNOR_99TJ TJ Wrangler Technical Forum 20 05-31-2010 09:35 AM
Center console lock...HELP Gambler 2100 TJ Wrangler Technical Forum 2 07-12-2006 10:15 AM
I want to get at my center console sub and replace it. deliverator TJ Wrangler Technical Forum 1 01-17-2003 02:50 PM
