CEL P0304 Intermittent Camshaft Sensor Error - JeepForum.com
post #1 of 12 Old 02-17-2017, 08:06 AM Thread Starter
Dooshene
Hello, for the past couple of months i have been dealing with the Dreaded P0344 CEL
This error will generate when starting my Jeep in the Morning when the Temperature is below 30 Degrees Fahrenheit
Looking through past forum threads, i have been attempting to troubleshoot, and have gotten closer but the error still appears.
Items that have been replaced: (Big Items are all Mopar/OEM)
New Battery
New Sparkplugs (Stock gap recommendations)
New Coil Pack
New Camshaft sensor
New Crankshaft Sensor
New O2 sensors (All 4 were replaced in correct order)
New Starter
New Fuel Pump
Fuel Pump was the most recent install
There is no hesitation when starting that is noticable, there was some prior to the fuel pump, but thats been remedied.
ECU was reset after every new install, so it could relearn based on the updated parts.
Kinda stuck at this point as far as what to try next.
This is not a emergency, just a annoyance as this will only occur once it goes below 30 degrees, any higher it does not occur.
Weird Symptom that i noticed.
After every 5 starts over the course of the day, the light goes out by itself: (I'll break it out below)
1 - Going to the Gym @ 4:30 am
2 - Coming home from the gym
3 - Going to work
4 - Going to Lunch
5 - Coming back from lunch (The Light does not generate when starting)
Any help/guidance would be appreciated.
Hopefully i only have another month of cold weather
Last edited by Dooshene; 02-17-2017 at 11:41 AM. Reason: Typed wrong CEL: Should be P0344
Dooshene is offline
post #2 of 12 Old 02-17-2017, 11:10 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
P0304 is cylinder 4 misfire. Isn't it P0344?
Rubi4MyMrs is offline
post #3 of 12 Old 02-17-2017, 11:41 AM Thread Starter
Dooshene
You are correct, typo on my Part
Dooshene is offline
post #4 of 12 Old 02-17-2017, 12:20 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
You are not alone. Search that code & see.
Any chance you recently replaced the OPDA with a Dorman or Crown? If yes, hopefully you have the old, original sensor. If so, put it in the new OPDA & see what happens.
post #5 of 12 Old 02-17-2017, 01:08 PM Thread Starter
Dooshene
I only replaced the sensor, the OPDA itself is still stock. That might be my next replacement.
The Sensor i bought was the mopar one from the dealer, i had read bad reviews about Dorman and Crown, so i got mopar for all my sensors.
Dooshene is offline
post #6 of 12 Old 02-17-2017, 01:15 PM
Speed911
I've been dealing with mine for years with no luck. Good luck, you're going to need it
****, I wish I had read that before. This is my first time seeing this suggestion. Mine is long gone
Speed911 is offline
post #7 of 12 Old 02-17-2017, 01:35 PM Thread Starter
Dooshene
Going to Order a New OPDA as that is the only Part i haven't replaced. And the one in their still looks stock.
In regards to the Sensor, i replaced it with a Mopar one when i originally started testing, but then a light went off in my head and realized that my family's mechanic replace the sensor recently and come to find out he used a ****ty autozone brand one.
So i just ran outside while at work and swapped them, realizing he put the old one in a box in the rear area.
Hopefully by putting the good one back in, this will resolve. If not, i will replace the OPDA and continue to use the Mopar CPS.
Should i go with the Crown OPDA or is there another brand that people like to use.
Dooshene is offline
post #8 of 12 Old 02-17-2017, 02:17 PM
Speed911
I went wth Crown and new oem sensor. Dorman also makes a replacement. Not sure what the differences are or what the consencous is on preference over one or the other.
-Dane
Speed911 is offline
post #9 of 12 Old 03-13-2017, 07:59 AM Thread Starter
Dooshene
Update
Crown OPDA and a New Original Camshaft sensor has resolved my issue.
Installed and cleared the code. Jeep fires right up no matter how cold it is.
I was able to find a original Cam sensor from a vendor.
The one is used is:
Jeep
P#: CAM103-OE
Vendor: AIP Electronics
$20.00
They have their own site, and a vendor page on Amazon. Free shipping, took only a few days to arrive
After trying Mopar and other brands, this was the only one that worked, and i noticed a big difference.
Dooshene is offline
post #10 of 12 Old 03-15-2017, 04:58 PM
FireMedic82
The one is used is:
Jeep
P#: CAM103-OE
$20.00
Cool! Thanks for the info. I'm among the P0344 folks. So far, I'm on my second replacement. This one being a Dorman, and I haven't had any problems, YET...knock on wood. Too soon to know for sure. I've ordered the one from API to keep on backup.
Throw the photoshoppers a bone and post your executed mods, we would like to see the after pics. Copy and paste the url. http://www.jeepforum.com/forum/f59/executed-photoshop-mods-1417032/
FireMedic82 is offline
post #11 of 12 Old 03-21-2017, 12:42 PM
Speed911
The one is used is:
Jeep
P#: CAM103-OE
$20.00
Just ordered. I'll come back and let you all know what happens with mine and the crown opda.
-Dane
Speed911 is offline
post #12 of 12 Old 03-24-2017, 01:47 PM
Speed911
Nevermind, they're out of stock for at least 4-6 weeks. I'll be trying the gap method.
-Dane
Speed911 is offline
