CEL codes PO1294 and PO1492? - JeepForum.com
post #1 of 11 Old 09-20-2010, 08:42 PM Thread Starter
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
cant find anything on either of these two codes. pulled these this morning.
TIA
Mail crawling.
MisfitSeven is offline
post #2 of 11 Old 09-20-2010, 09:00 PM
BEANS
BEANS's Avatar
CODE: PO1294 - Can't get to target engine speed, check for vacuum leaks and idle speed motor issues.
PO1492 Ambient/Batt Temp Sensor Volts Too High
2001 SPORT 4.0 AUTO EMPTY GAS TANK
2 1/2"O.M.E. 1"Body LIFT
33" DUNLAP'S
JSK QUICK DISCONNECTS THAT I'LL NEVER DISCONNECT
LIMITED SLIP WITH 4.11'S FRONT AND BACK
S.Y.E
7'6" SNOWAY POLY PLOW
Elect Radiator fan on a Delta control
Borla Header, Catback Exhaust By Volant 304SS
BEANS is offline
post #3 of 11 Old 09-20-2010, 09:05 PM Thread Starter
MisfitSeven
MAiL Crawler.
i will clean the IAC tomorrow, this is most likely my problem for PO1294.
as for PO1492, is this that sensor under the battery with the spring, on the stock fenders? or is the battery temp sensed in the computer?
Mail crawling.
post #4 of 11 Old 09-20-2010, 09:08 PM
BEANS
BEANS's Avatar
under the Battery
33" DUNLAP'S
S.Y.E
BEANS is offline
post #5 of 11 Old 09-20-2010, 09:41 PM Thread Starter
MisfitSeven
MAiL Crawler.
maybe the reason that code is popping up is because i threw it away when i put the new fenders on. sound about right? what is that sensor called? battery temp sensor?
i pulled 4 codes this morning:
PO320... crank sensor is 3 months old, would this be the cam sensor under the cap in the distributor?
PO138... i am guessing because i have no cat or rear O2 sensor that this is the cause of this code.
PO1294... clean the IAC...
PO1492... do i really need this sensor?
thanks for the help.
Mail crawling.
post #6 of 11 Old 09-20-2010, 09:58 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yep. Get another one, plug it back in and tie it back to the wiring harness...
Knuckelhead is offline
post #7 of 11 Old 09-20-2010, 10:28 PM Thread Starter
MisfitSeven
MAiL Crawler.
tie it to the harness... shouldnt it be sensing the temp of the battery... or does it just need to be hooked up?
Mail crawling.
post #8 of 11 Old 09-21-2010, 06:26 AM
Knuckelhead
AFSOC Retired
You have no cat?...
post #9 of 11 Old 09-21-2010, 06:35 AM
BEANS
BEANS's Avatar
I'm running a Catalytic converter. Just noticed my muffler is leaking, good excuse to buy a complete catback system. Headers to tail pipe.
33" DUNLAP'S
S.Y.E
BEANS is offline
post #10 of 11 Old 09-21-2010, 07:09 AM
Knuckelhead
AFSOC Retired
You all ready have the best exhaust manifold there is on your 2001, the OEM one...
post #11 of 11 Old 09-23-2010, 05:58 PM Thread Starter
MisfitSeven
MAiL Crawler.
You have no cat?...
no. my exhaust is 60" long, from cylinder head to the tip of my tailpipe. for now...
Mail crawling.
Which Dupli-color Codes (spray paint) Equal Our Paint Codes? djt283 TJ Wrangler Technical Forum 10 12-28-2011 11:18 AM
Codes....codes....codes!!! Need guidance!! cnt487 TJ Wrangler Technical Forum 1 05-22-2010 05:27 PM
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 06:05 PM
CEL codes 01amberfirewv TJ Wrangler Technical Forum 3 10-19-2006 11:36 AM
got some codes...how to fix em? bananamane YJ Wrangler Technical Forum 4 12-11-2005 11:30 AM
