CEL can't make up its mind. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > CEL can't make up its mind.
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 07-03-2013, 10:14 AM   #1
OzzLee
Bought an 05 TJ three weeks ago. First Jeep. I love it....even with the death wobble....wakes you up quicker than two pots of coffee.
DW is not why I'm here. I'm here because this past week my check engine light has gone nutty. I start the Jeep and it's off. A mile or so, it comes on for 5-10 seconds and shuts back off. A minute or two later it turns back on and is flashing and dinging and waiving its arms saying "LOOK AT ME LOOK AT ME!" and after a few seconds it shuts off. Off, on, off, on, off, flashing, off, on, flashing, off.....well you get the picture.
I took it to the auto parts store to have the code read, and was told they couldn't because the light isn't on. They told me what ever problem I was having, it was quickly correcting itself. I don't notice anything wrong when the light comes on, but Jeeps are new to me.
Has this happened to anyone else? Please tell me its simple, like a loose fuse, and not something ready to explode and I shouldn't even drive it to the end of my driveway.
OzzLee is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 01:16 PM   #2
NotURMailman
NotURMailman's Avatar
I hate to tell you this but mine did this a few times a couple of years ago and I never figured out why. Never really worried about it though because there weren't any other symptoms.
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 01:21 PM   #3
biffgnar
biffgnar's Avatar
Has happened two or three times to me. I think always after extended periods of driving at highway speed in heavy rain. Always assumed a sensor or something had gotten wet and didn't like it but then dried quickly from engine heat. Who knows? No consequences that I've ever been able to determine.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 05:29 PM   #4
pwmac
Erratic CEL could be the first sign of a bad OPDA. Better check it.
Lots of fixes for that problem. Easy to check after viewing the video on page 1 of the monster thread of the subject.
Good luck, PW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline   Reply With Quote Quick reply to this message
Unread 07-03-2013, 06:26 PM   #5
biffgnar
biffgnar's Avatar
Good luck, PW
Possible, but personally the episodes I related have happened over lets say the last five years so very scattered and I'm at 136k on stock OPDA, so while checking that is a good thing if you have an 05 or 06 I dont' think it is what caused it for me.
Unread 07-04-2013, 10:03 AM   #6
OzzLee
Good luck, PW
I would like to extend my thanks. After finding the thread you suggested, I'm positive it is my OPDA going bad. I have the "laughing Monkey" sound, though not nearly as bad as in the video. At times it makes no noise at all. I started looking at the oil pressure gauge as well, and noticed it drop pressure and then quickly regain it again. My CEL comes on when it drops the entire way. I hadn't noticed this since it happened so quickly and I wasn't focused on the gauge.
I'm glad you mentioned this before it quit completely and did some serious damage. Cheers to you
Unread 07-04-2013, 12:22 PM   #7
Dead_End
1990 XJ Cherokee
Did they tell you they couldn't hook it up with the light off, or did it not pull up any codes? The ECU should have whatever code was throwing the light stored as "pending" and should still show up on a scan tool.
[/Kevin]
_____________________________________________
Jurassic Park '90 XJ, '00 TJ
Dead_End is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 12:53 PM   #8
meatlord
animals taste good
meatlord's Avatar
X2. The code will still be readable even if the light is off.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" FOR SALE. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 03 Nissan SE-R 6 speed V spec. / 00 Suzuki DR650.
meatlord is offline   Reply With Quote Quick reply to this message
Unread 07-04-2013, 01:30 PM   #9
pwmac
Cel
I believe its true that codes are set and readable when the CEL is off.
Intermittent CEL if caused by wear on the drive gears always start out as intermittent. Reason the worn gears cause slop and the cam position sensor goes in and out of the sweet spot and the ECU compensates when the tone ring/sensor moves out of tolerance.
Never neglect any kind of CEL whether intermittent or not.
PW
pwmac
Durango, CO
Unread 07-04-2013, 01:39 PM   #10
OzzLee
Figured it out. When I bought it, the sticker said I still had 3k miles before my next oil change. I figured it was recently serviced. Checked the oil....bone dry. Put a quart in, and it held pressure. Definitely going to keep an eye on it now that I know the OPDA is notorious for going bad.
cel , check engine light
