#1 | |
cb radio mount
Higuys. I just bought a Cobra 29 nw CB and I was looking around my cab and I can't find a good place to mount it. Anyone have any ideas they want to share.
------------------ 99 TJ 4.0L TB spacer K&N Soon to be 3" taller with 33s
#2 |
panhd,
run a search using the words "cb radio" and all open forums instead of just the tj one - it'll give at least 17 different subject threads to go through. at least it just did for me. that oughta give you plenty of ideas to keep you busy for awhile. good luck.
2003 TJ Sport - mine, 2001 TJ SE - hers 2001 XJ Sport - ours, 1987 XJ Chief - ours 2000 TJ Sport - sold, 1993 XJ Sport - totaled 1987 XJ Laredo - sold, 1953 CJ-3B - sold |
#3 |
Locked @ both ends
Mine is mounted on the roll bar between the driver and passenger.
#4 |
Thanks for the advice guys. I'm gonna try that search Quad...
#5 |
I am multitasking! I'm typing and pissing you off at the same time! |
#6 |
quick question.. how heavy duty is that mount that turbo city sells? i only wonder because my radio is heavy and i dont want it screwing up the windshield frame by pulling out or bending while going over big bumps..
Awwwwwwwwwwww... So he wants to go OFF-ROAD does he???? '93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN! "The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke |
#7 |
It's pretty stout. I only use the two screws that attach the footman loop to the windshield frame, but it does have three additional hole so you can mount it more securely if you need too.
| Tags |
| cb, cb mount |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
