caster - JeepForum.com
post #1 of 10 Old 03-22-2011, 07:48 PM Thread Starter
duke04
caster
OK, I have the death wobble that has just gotten worse. I'm looking at the front upper and lower control arms on my 2004 TJ and it looks like there are adjustment cams on both. I know I tried the lower cam sometime back and it didn't move. Does the upper cam work and adjust? Or is it for looks too?
I see that the older TJ's have adjustment cams, can they be installed on a 2004?
Thanks for any info and help.
Terry
02 Harley, 04 Jeep X, Both Black
Black Jeep #63
duke04 is offline
post #2 of 10 Old 03-22-2011, 08:11 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Terry
A 2004 doesn't have adjustment cams from the factory, you need to buy them. They only go on the front lower control arm mount at the axle. The uppers are fixed length and do NOT have cams.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 10 Old 03-22-2011, 08:25 PM Thread Starter
duke04
Thanks, it sure looks like the uppers have a cam, too.
Black Jeep #63
duke04 is offline
post #4 of 10 Old 03-22-2011, 08:27 PM
Unlimited04
they do not. its a flag nut to prevent rotation of the nut when torquing it down on the assembly line.
Useful Write-Ups:
Funny:
post #5 of 10 Old 03-23-2011, 04:20 PM
wushaw
Rockin jeep
wushaw's Avatar
You have death wobble and your trying to adjust castor?
wushaw is offline
post #6 of 10 Old 03-23-2011, 04:31 PM
BillDog103
While you are looking at those control arms... have a good look at the bushings. That is most likely your culprit. but check all of the usual suspects. Steering linkages, ball joints, balance of tires, etc.
BillDog103 is offline
post #7 of 10 Old 03-23-2011, 04:38 PM
Tblack
Death wobble is usually caused by incorrect steering geometry. Check your bolts (Track bar bolt, bushing, and rod end) and angles. and im not trying to be rude, but 9 times out of 10 a buddy is crying death wobble when its really just a good shimmy that can easily be fixed. Death Wobble dang near makes me need to steam clean my seat. Death wobble may also be triggered by something like tires out of balance. Something has to trigger the death wobble i.e. Potholes, bumps, etc.
Just some tips.
Safety 3rd!
Tblack is offline
post #8 of 10 Old 03-23-2011, 05:40 PM
Imped
Imped's Avatar
No it's not.
DW occurs when the front end can't control the tires....something is either loose or worn. If the front end is tight and in good shape, unbalanced tires won't cause DW. That's all pretty irrelevant to steering geometry (not sure if that's the term you were looking for) and alignment.
Hint: It's not your caster. You don't need to go messing with those dumb cam bolts. You need to find the source of the wobble.
OlllllllO
IndyORV
Imped is offline
post #9 of 10 Old 03-23-2011, 06:20 PM
cj847
No it's not.
I agree it's probably not caster, but DW is OFTEN caused by tires. I've had a set of tires that simply could not be controlled. I even put BB's in them to try to balance and couldn't get it done (besides the weights that were put on at the tire store). I have done nothing to the front of my jeep since then and put an old beat up set of 35's on it and there are absolutely no problems. Can drive hands free 0 to 70 mph.
DW is a harmonic vibration. If your setup hits the proper rythym it doesn't matter how good your parts are, it's gonna go crazy.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #10 of 10 Old 03-23-2011, 07:49 PM
Imped
Imped's Avatar
And if that harmonic can't start, then it doesn't matter. Small, worn, or flexible parts allow that harmonic vibration. A good front end won't let it get out of control. I can drive on my tires unbalanced all day long....there might be a couple minor hops/wobbles every now and again, but it never turns into DW.
OlllllllO
IndyORV
Imped is offline
is 4.5* enough caster? 98TJWV TJ Wrangler Technical Forum 8 10-05-2010 10:49 PM
Caster???? lawson1273 TJ Wrangler Technical Forum 18 10-20-2009 03:34 PM
is too much caster bad?? 4luck0 YJ Wrangler Technical Forum 3 09-25-2009 03:51 PM
Is my caster okay? BulldogTJ98 TJ Wrangler Technical Forum 13 07-21-2009 09:23 PM
toe-in / caster bradleyfitz TJ Wrangler Technical Forum 8 12-16-2005 03:54 PM
