carrier break? - JeepForum.com
post #1 of 7 Old 07-26-2011, 08:17 PM Thread Starter
silverjeeper
carrier break?
Ok i am changing gears from 3.07 to 3.73 for a d30 and theres supposed to be a carrier break at 3.54 right? Well bought a 3.73 carrier from east coast supplies and theres no difference. The carrier is no taller and 3.07 and 3.73 are same distance apart . Im having a friend look at it whos a corvette speciallist and doesnt think theres any reason to change the carrier cuz the ring depth comfinsates for the pinion thickness. So is the carrier break just a myth and i wasted my money or r we missing something.
silverjeeper is offline
post #2 of 7 Old 07-26-2011, 08:46 PM
NotURMailman
NotURMailman's Avatar
I'm honestly not sure what the exact difference is, I never thought about it. But, there is something different. Maybe the diameter of the carrier where the ring goes around it? Maybe the bolt pattern spacing? You didn't waste you money, you did the right thing.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 7 Old 07-26-2011, 08:55 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Carrier breaks are not a myth. The lower the ratio of the ring & pinion gears, the smaller the diameter of the pinion gear. I.E. the pinion gear of the lower ratio 4.88 has a smaller diameter than the pinion gear of a higher ratio 3.73 has.
With a smaller diameter pinion gear as you'd get with a lower axle ratio, the ring gear teeth have to be moved closer to the pinion gear so the teeth can mesh. A carrier for a lower ratio axle ratio moves the ring gear closer to the pinion gear so their teeth can mesh properly.
The only way around using a different carrier once you reach that magic "carrier break" ratio is to use a "thick" ring gear which does the same thing... it's a thicker ring gear that positions the teeth close enough to the pinion gear so they mesh properly.
Getting
Jerry Bransford is online now
post #4 of 7 Old 07-26-2011, 09:00 PM
TiredOldMan
TiredOldMan's Avatar
Nevermind, Jerry has faster fingers.
Looking for MB Shock wheel 15x8 5on4.5 3.75bs
" The problem with socialism is that eventually you run out of other peoples money"
Margaret Thatcher
TiredOldMan is offline
post #5 of 7 Old 07-26-2011, 09:00 PM
NotURMailman
I wish I would have caught you earlier. I still have my OE 3.73 gear sets and carriers.
post #6 of 7 Old 07-26-2011, 09:08 PM
TiredOldMan
Sent you a PM
Margaret Thatcher
post #7 of 7 Old 07-26-2011, 10:13 PM
cj847
The two carriers are identical except for the surface where the ring gear mounts. The machined surface is moved over about 3/8". Unless you hold them side by side you won't notice the difference.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
Carrier break/ GunDude JK Wrangler Technical Forum 7 06-21-2011 01:37 AM
Anybody break 8.8 carrier? Truth YJ Wrangler Technical Forum 9 02-10-2010 11:06 PM
the carrier break ImpactFabWorks YJ Wrangler Technical Forum 8 04-19-2009 09:12 AM
Dana 30 w/ 3.07s - carrier break? timdastis TJ Wrangler Technical Forum 4 11-29-2008 06:48 PM
what is the carrier break? rsoffar YJ Wrangler Technical Forum 6 02-14-2006 08:13 PM
