Can't shift into Park or 1st Gear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Can't shift into Park or 1st Gear
Warn, Smitybilt, Engo, Rugged Ridge Winches at CCORJKS Flex Connect in Actions!CCOR is Hiring! Athens, GA!
Unread 01-30-2008, 11:42 AM   #1
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
All of sudden I am unable to put in park or 1st gear with my 2004 TJ auto tranny. The shifter will move freely to Reverse to 2d gear, but will not go into Park or 1st gear -- feels like something is blocking it. Of course, ignition key is stuck in steering wheel. Any ideas on what the problem is?
I have 59K on the clock, so I'm thinking this will be covered by Powertrain warranty?
2009 JK Rubicon (Former Daily Driver); 2014 VW Jetta GLI Autobahn w NAV.
Auto, Power, Remote Start, Towing Package, MyGig Navigation with Lockpick, Rear View Camera, B&M 70268 Transmission Cooler, Aeroforce Interceptor, Valentine 1, Tub Sound-Deadened with Raamat and Ensolite, Hard Top Heat Insulated with 1/2" Styrofoam Insulation, Bilstein Shocks Front & Rear, PIAA Dual Horns, IPF 920H4 Headlights.
Protection: Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear.
Recovery Gear: Warn 9.5Ti Winch, 11,000# Pull-Pal.
Communication: Uniden 520XL CB, Diesel External Speaker, 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti Winch -- Ordered 7/17/2009; Bumper Received 12/4/2009.
1" Coil Spacer Front & 1/2" Coil Spacer Rear restored OEM Rake.
4x4 Trips:
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013
Ouray - 8/2007
Rubicon - 9/2008
Gone, but not forgotten: 2004 TJ, 1999 Audi A4, 1992 VW Jetta GL 5 Speed
Thunderstrike is offline   Reply With Quote Quick reply to this message
Unread 01-30-2008, 11:52 AM   #2
TJDaveX
Fail rated
TJDaveX's Avatar
Most of these problems usually have to do with that brake pedal shift interlock gizmo. I have not had any problems w/my '04 auto---YET! Someone is sure to chime in as I've seen it mentioned before. I'm interested also, so I know what to do when it happens to me.
TJDaveX is online now   Reply With Quote Quick reply to this message
Unread 01-30-2008, 01:14 PM   #3
kmoney67954
Something simalar happened to me awhile back. I took the cover (center console) that is over the shifter part way off and saw that the metal rod on the bottom of the shifter that locks it into each gear was bent, preventing it from going into park. I got a pair of pliars and straitend it out, now it works flawless again.
kmoney67954 is offline   Reply With Quote Quick reply to this message
Unread 01-30-2008, 01:17 PM   #4
Thunderstrike
2009 JK Wrangler
OKAY, let me check it out. Thanks.
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
Unread 01-30-2008, 04:05 PM   #5
BlueFlame
Push the clutch in further...
BlueFlame is offline   Reply With Quote Quick reply to this message
Unread 01-30-2008, 04:11 PM   #6
otisdog
2008 WK
I think I've heard someone say there is a plastic pin in the shift handle that wears and will cause this. Pull the handle off. Replace it with a metal pin?
Jim
08 Grand Cherokee Overland
otisdog is offline   Reply With Quote Quick reply to this message
Unread 01-30-2008, 05:04 PM   #7
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
That exact thing happened to me...on Argentine Pass at 13,000ft after a 2 hr off road drive over large boulders. Had to decend in 2nd & 4Lo - it wanted to go 20mph, had to ride the brakes the whole way.
Anyway - a pin broke inside the shifter/transmission housing (according to the dealer). It was replaced under warranty.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 02-01-2008, 04:14 PM   #8
Thunderstrike
2009 JK Wrangler
I got the shifter fixed today. I removed the auto transmission shifter handle by pulling upward. Need some force to remove it, and there's no screws or anything.
Then I checked all components to see anything is broke but all looked good. When I push the metal rod at the bottom of shifter I could hear a click from the safety that prevents from being shifted when brake is not pressed.
If you can shift freely with this metal rod being pressed down (with a flat screwdriver), then the auto shift cable or safety lock are functioning properly. You now know it's the white plastic ball-stick is the one that's broken.
When I press down the white plastic, the rod in the circle wasn't pressing down enough.
When I pulled the white plastic rod, I noticed it was broke at the bottom and the broken piece was stuck in there. Dealer said I had to buy the whole assembly because the pastic road wasn't showing up as a part that could be ordered.
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
Unread 02-01-2008, 04:20 PM   #9
Thunderstrike
2009 JK Wrangler
Well, so I used a wooden chopstick, one with larger head at one end, and cut it to the same length as the broken piece.
I wrapped two sided sticky tape to prevent rattling.
I replaced the handle back into the shifter rod, and it worked flawlessly. Shifts out of park with brake depressed; will not shift into/out of park without the brake being depressed.
It took sometime for me to figure this out and everything looked good, and the park/brake interlock cable seemed to be OK. So, I decided to check the shift level handle and its button. That's when I found the broken plastic rod.
I didn't have to remove the console... just remove the shift bazel light/socket piece.
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
Unread 03-07-2008, 08:01 PM   #10
Jeff5886
1983 CJ5
did you leave the broken piece in or did you pull it out?
Jeff5886 is offline   Reply With Quote Quick reply to this message
Unread 03-07-2008, 08:49 PM   #11
Thunderstrike
2009 JK Wrangler
Yes, I left the broken piece in there. The broken piece is stuck in the bottle of the verticle shifter rod. The small broken piece in the pic above is just for illustration.
4x4 Trips:
Ouray - 8/2007
Rubicon - 9/2008
Unread 03-07-2008, 08:59 PM   #12
otisdog
2008 WK
pics no show - would really like to see them.
Jim
Unread 03-08-2008, 07:10 AM   #13
robncar
What's a clutch?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline   Reply With Quote Quick reply to this message
Unread 03-08-2008, 05:53 PM   #14
otisdog
2008 WK
Ok here's the pics
Unread 03-13-2008, 11:06 AM   #15
petrolv
auto shifter stuck in gear
.....Have the same problem...if you pull the handle off the shifter(need something pointy to pry the fingers apart underneath) then there is a plastic shaft that goes down the tube. It has plastic balls spaced apart about 1/2 inch to keep it centered in the tube as the tube has a bend. Yours is broke....more than likely at the bottom ball. Once you have the shift handle off you can depress the plastic shaft with your thumb and it will shift and you can get your key out till you replace the measly part. I see this is a older post but I'm addressing it as I was told by a service manager when I tried to order the part that so many break he is surprised there is not a recall...
petrolv is offline   Reply With Quote Quick reply to this message
42rle , 42rle auto shifter , auto shifter
